Results 1 to 29 of 29
    Aug 2004
    i am a real newbie to making DVDs :roll
    i have a 1 gig athon 512 MB RAM WIN me computer witha botu 10 gig free on the hard drive ( 40gb total)
    i have a sony external USB DRX- 510UL DVD 4X dvd+/-RW burner for my pc
    i have a bunch of DVD+R's and a few DVD+rws
    i am trying to transfer all my vhs tapes to dvd format but i discovered that the most u can fit it only 2-4 hrs MAX on a 4.7 gig
    i know u can store more on certain DVD- RAM but they are like over 15 bucks a pop now! which isnt cost effective. i could go buy the original movies for that price, and i dont think my DVD burner i just bought will copy data to them( expecially the 8GB DVD-RAMs
    i have heard u can put at least 6 hours or so of video /audio onto a DVD in VCD format or DVD-VCD i think
    i have a video capture device for pc to transfer all my vhs tapes to my computer in a MPEG 1 or 2 format. i know how to do that already
    but putting them onto a dvd in vcd format is what has excaped me.
    i want be able to play it in a standard new player that can dvd play in my computer, and a standard new DVD player that can read VCDs,SVCDs, DVD+/-RW( i have a KOSS KD-305 player now that can do this)
    i heard u can do most of the work with a program svcd2dvd ,but when i went to the website and dled the trial it already expired
    can someone explain to me EXACTLY how do take a mpeg file and put it onto a DVD in vcd format and can play in a dvd player i mentioned above
    ( keep in mind i am a newbie and may not understand some terminology)
    is there a way to use any type of freeware available to do all this?
    Is there ANY product available for free or not that can do it all in 1 shot instead of using half a dozen programs to convert, author, demultiplex. etc? and have the audio be in sync and everything?( i would definitly prefer free over not) i have never dvd authored before and ive tried it and it hasnt worked already wasted a few blank DVDS. its very hard to understand
    the problem is i have already read the how to guides on this website regarding that but either most the how to guides apply to software that doesnt exist anymore ( older versions) and the guides cant explain how to the new ones work. its all very confusing ,
    the reason i want to put it in vcd format is becuase all my tapes are 6-8 hours FULL of movies tv shows, etc and it would be actually impractical to put them onto a 4.7 gb DVD+R at 2 hours at a time, not that i would mind viewing the clear picture in dvd format but lack of space makes it too impractical for me and since the vhs tapes are already less than dvd quality why bother only putting that on a dvd at 2 hours at a time?
    im trying to conserve space in house i dont want to end up with back up 100 vhs tape onto 300 dvds! with the dvds+rs at a few bucks a pop
    if anyone can please help, and explain to me how i can do this in LAYMAN terms with currently programs availiable in the easiest, fastest and cheapest way i would greatly appreciate it. thanks
  2. Member mats.hogberg's Avatar
    Jul 2002
    Sweden (PAL)
    Provided your mpegs are already to VCD specs, the only thing you need is TMPGEnc DVD Author. It handles VCD mpegs and adjusts the audio to fit DVD specs (video already is) automatically.
    /Mats
  3. Member pchan's Avatar
    Mar 2003
    Singapore
    I think I have asked this question before.
    https://www.videohelp.com/forum/viewtopic.php?t=234627&highlight=
  4. Provided your mpegs are already to VCD specs, the only thing you need is TMPGEnc DVD Author. It handles VCD mpegs and adjusts the audio to fit DVD specs (video already is) automatically.
    I highly recommend Tmpgenc DVD Author (TDA). However I don't use it for the actual burning of the DVD because when I last tried it the DVD wouldn't play. I use Nero for the burn instead.
  5. Member mats.hogberg's Avatar
    Jul 2002
    Sweden (PAL)
    ...and I prefer ImgTools Classic + DVDDecrypter - but that's minor details. Generally speaking you ought to be able to burn with TDA too.
  6. Look in the guides under "Author" - they're in there. Here's one that may help you the most:
    https://www.videohelp.com/guides.php?guideid=533&howtoselect=3;29#533
    As mats.hogberg has already said, TMPGEnc DVD Author will handle a VCD file just fine so this guide is not needed.
    Cobra
    Aug 2004
    regarding TMPGEnc DVD Author; someone said it does it automatically
    (im a newbie remember )how do u do it in the settings?? which main settings do u use do it
    in TMPGEnc DVD Author, do i need to just author it then burn to dvd? or is there another things i need to do?
    and also said someone burned it with nero
    i have nero burning rom 6. i used it to make standard vcds,is that the right nero to use?
    if not, which nero program do i need to burn to the dvd and which settings in nero do i use??
    and for either program:how to i burn it as ? a vcd? a dvd ? a dvd-vcd? which one
    regarding someone who said imgtools classic and dvdencrypter which settings do u use in each? do u authto in imgtools and then burn in dvd encrypter? what????
    also is there a specific Version i need of TMPGEnc DVD Author or imgtools or dvdencrypter or NERO to do ANY of this???if so please tell me which ones
    thank you for all your replies so soon i greatly appreciate all your help , thank you
  8. regarding TMPGEnc DVD Author; someone said it does it automatically
    You said you allready know how to capture so just capture at VCD settings (352x240 , 1100 kbps or something like that) but change the audio from 44 to 48.
    Then just open TDA and start a new project and then use the "ADD VIDEO" button.
    TDA is easy to use but you will have to experiment a little. You can use each video clip as a title or you can have one title and each clip will be a chapter, or you can have several titles with several clips in each title.
    Go ahead and use TDA to burn too. It will probably work fine. I just had some trouble and went back to using Nero because I was used to it.
    If you do use Nero just choose the DVD Video setting. You will have to navigate to the files made by TDA which are in your Documents and Settings/Tmpgenc DVD folder.
    Aug 2004
    ok so i need to reencode the mpeg-1 file ( i use tmpgenc plus) AGAIN to mpeg-1 ,,, but this time force it to be set to 48 k?
    so im converting mpeg-1( 44k audio) to mpeg-1(48K audio), correct?
    and then use dvd author? and do add video?
    i have tmpgenc dvd author 1.6 now ill try that first but if somethign goes wrong ill check it out with nero
    u said had some trouble with tda? well which nero can i use? and which version. i have nero burning rom 6.0
    nero burning rom just says it can create an: audio cd , mixed cd, vcd, svcd, mini dvd, cd extra, cd copy, and cd-rom boot/hybrid/udf/udf-iso
    and if i use any other software and after i dvd author it all and ptu ti to a folder on my pc , if i use other burner software what would i need to burn it as? just a standard DVD? or a vcd? and just put a dvd disk in my burner????
    thanks.
  10. You don't need to re-encode the mpegs.
    Just load then into TDA which will resample the audio to 48K.
    Needn't worry about other people's troubles, its not yours until you encounter the same problem.
    Author and burn with TDA.
    Aug 2004
    i tried to cliocl on the write dvd folder dvd rw folder button
    but i got this error:
    PSAPI.DLL file is linked to missing export NTDLL.DLL:NTAllocateVirtualMemory
    how to fix this problem? or if i CANT, what other burning software can i use to burn the DVD folder to the dvd+r?
    Aug 2004
    i think i found out why i get that error i believe tmpgenc 1.5 and later runs on XP
    apparently windows ME doesnt totally run Tmpgenc DVD Author 1.6. well
    i have windows ME so even thought i can create the dvd files i cant burn with it
    does anyone know of a good free or trial burner software which will easily and properly burn my vcd files to a dvd which i created with the TDA????
    thanks
  13. You don't need to re-encode the mpegs.
    I should have mentioned that you would not need to re-encode just for the audio since TDA can correct that for you. But remember to capture at 48K in the future because it will speed up TDA's creation of the DVD.
    thanks
    Yes, I think you are correct that the burning engine for TDA will only work on XP. So what's wrong with burning with Nero?
    Oh, I see the problem. I think those are all CD types. You need to switch to DVD burning. I think there is a button at the top of the list that changes that.
    Just drop the files made by TDA into the VIDEO_TS folder in Nero.
  14. Banned
    May 2003
    Massachusetts
    *ahrm*
    Ok, there are TWO ways to do what you want.
    You can either use super-low-res DVD, which is the same resolution as VCD only with, as others have stated, a higher audio sampling rate.
    OR, IF your player supports it, you can make a VCD-DVD. The best/easiest program to do this is one called ... dammit, I forget. VCD2DVDMPG+ or something like that. I tested it for the author for a while, until we realized that my Pioneer player just wasn't ever going to like those discs. But many do.
    So if you already have a lot of VCD's, that program is a real timesaver, and pretty cheap to boot.
    But if you are capturing the video now, just capture it at 48k like everyone said.
    - Gurm
    Aug 2004
    how do u use nero burning rom 6 for this? can someone telll me exactly what to do or do i need a nero burning dvd
  16. Here is a step by step guide:
    http://www.doom9.org/index.html?/mpg/nero-dvdburn.htm
    (Tip: I found the above guide by going to Google.com and typeing in "Burning a DVD with Nero")
    Aug 2004
    i had nero burning rom 6
    i upgraded to 6.3.1.2 and i still cant see the way to make a dvd with it
    ther is no wizard when i start up nero burning rom
    it shows u which to CD or mini dvd to make
    but thats it, no dvd-video options
  18. Member mats.hogberg's Avatar
    Jul 2002
    Sweden (PAL)
    Nero obviously doesn't recognize your writer - Skip Nero and use ImgTools to create image, then DVDDecrypter to burn the image. Life's too precious to fight with software that doesn't work...
    /Mats
  19. i have a sony external USB DRX- 510UL DVD 4X dvd+/-RW burner for my pc
    Your DVD burner must have come with some software. Can you burn with that?
    I don't think it is a question of Nero not working. If Nero doesn't recognize his burner he needs to troubleshoot that. When I installed my internal DVD burner I had to get the latest firmware in order for it to be recognized.
  20. ther is no wizard when i start up nero burning rom
    Did you read the guides that were pointed out to you?
    Aug 2004
    i got the burner 2 weeks ago from online
    it was refurbished
    i upgraded the firmware already
    i already made an audio cd, and copied a date file to a dvd
    it can read both standard cds and dvds
    i figured out now to burn with nero to a dvde but got this error:
    Windows 98 4.90 (ME)
    IA32
    WinAspi: File 'Wnaspi32.dll': Ver=4.60 (1021), size=45056 bytes, created 9/10/1999 4:06:00 AM
    ahead WinASPI: File 'C:\PROGRAM FILES\AHEAD\NERO\Wnaspi32.dll': Ver=2.0.1.68, size=160016 bytes, created 7/22/2004 5:33:44 PM
    Nero version: 6.3.1.20
    Recorder: <SONY DVD RW DRU-510A> Version: 1.1a - HA 1 TA 0 - 6.3.1.20
    Adapter driver: <USBMPHLP> HA 1
    Drive buffer : 8192kB
    Bus Type : default (0) -> ATAPI, detected: USB
    CD-ROM: <Compaq DVD-ROM DV-5700B>Version: 1.23 - HA 0 TA 0 - 6.3.1.20
    Adapter driver: <ESDI_506> HA 0
    Compaq DVD-ROM DV-5700B (Target 0, E: Autoinsert On, DMA On, Disconnect ?, SyncDataXfer ?
    LG CD-RW CED-8083B (Target 1, F: Autoinsert On, DMA On, Disconnect ?, SyncDataXfer ?
    SONY DVD RW DRU-510A (Target 0, G: Autoinsert On, DMA ?, Disconnect ?, SyncDataXfer ?
    Excluded drive IDs:
    WriteBufferSize: 74448896 (0) Byte
    ShowDrvBufStat : 0
    BUFE : 0
    Physical memory : 511MB (523788kB)
    Free physical memory: 0MB (104kB)
    Memory in use : 61 %
    Uncached PFiles: 0x0
    Use Static Write Speed Table: 0
    Use Inquiry : 1
    Global Bus Type: default (0)
    Check supported media : Disabled (0)
    1.9.2004
    UDF/ISO compilation
    3:03:24 PM #1 Phase 112 File dlgbrnst.cpp, Line 1855
    DVD-Video files reallocation started
    3:03:24 PM #2 Phase 114 File dlgbrnst.cpp, Line 1855
    DVD-Video files reallocation completed (no file modified)
    3:03:24 PM #3 Text 0 File Isodoc.cpp, Line 6065
    Iso document burn settings
    Determine maximum speed : FALSE
    Simulate : FALSE
    Write : TRUE
    Finalize CD : TRUE
    Multisession : FALSE
    Burning mode : DAO
    Mode : 1
    ISO Level : 1 (Max. of 11 = 8 + 3 char)
    Character set : ISO 9660
    Joliet :FALSE
    Allow pathdepth more than 8 directories : FALSE
    Allow more than 255 characters in path : FALSE
    Write ISO9660 ;1 file extensions : TRUE
    3:03:24 PM #4 Phase 111 File dlgbrnst.cpp, Line 1855
    DVD-Video files sorted
    3:03:24 PM #5 Text 0 File Reader.cpp, Line 126
    Reader running
    3:03:24 PM #6 Text 0 File Writer.cpp, Line 124
    Writer SONY DVD RW DRU-510A running
    3:03:24 PM #7 ISO9660GEN -11 File geniso.cpp, Line 3899
    First writeable address = 0 (0x00000000)
    3:03:25 PM #8 ISO9660GEN -11 File geniso.cpp, Line 3899
    3:03:25 PM #9 Text 0 File Burncd.cpp, Line 3173
    Turn on Disc-at-once, using DVD media
    3:03:28 PM #10 Text 0 File DlgWaitCD.cpp, Line 247
    Last possible write address on media: 2295103 (510:01.28, 4482MB)
    Last address to be written: 349792 ( 77:43.67, 683MB)
    3:03:28 PM #11 Text 0 File DlgWaitCD.cpp, Line 259
    Write in overburning mode: NO (enabled: CD)
    3:03:28 PM #12 Text 0 File DlgWaitCD.cpp, Line 2162
    Recorder: SONY DVD RW DRU-510A, Media type: DVD+RW
    Disc Manufacturer ID: RICOHJPN, Media Type ID: W11, Product revision number: 1
    Disc Application Code: 0, Extended Information Indicators: 1
    3:03:28 PM #13 Text 0 File DlgWaitCD.cpp, Line 420
    >>> Protocol of DlgWaitCD activities: <<<
    3:03:28 PM #14 Text 0 File ThreadedTransferInterface.cpp, Line 813
    Setup items (after recorder preparation)
    0: TRM_DATA_MODE1 (CTransferItem)
    2 indices, index0 (150) not provided
    original disc pos #0 + 349792 (349792) = #349792/77:43.67
    relocatable, disc pos for caching/writing not required/required, no patch infos
    -> TRM_DATA_MODE1, 2048, config 0, wanted index0 0 blocks, length 349792 blocks [SONY DVD RW DRU-510A ]
    1: TRM_DATA_MODE1 (CTransferItem)
    2 indices, index0 (0) not provided
    original disc pos #0 + 1 (1) = #1/0:0.1
    relocatable, disc pos for caching/writing not required/not required, no patch infos
    -> TRM_DATA_MODE1, 2048, config 0, wanted index0 0 blocks, length 1 blocks [SONY DVD RW DRU-510A ]
    3:03:28 PM #15 Text 0 File ThreadedTransferInterface.cpp, Line 984
    Prepare recorder [SONY DVD RW DRU-510A ] for write in CUE-sheet-DAO
    DAO infos:
    MCN: ""
    TOCType: 0x00; Session Closed, disc fixated
    Tracks 1 to 2:
    1: TRM_DATA_MODE1, 2048/0x00, FilePos 0 0 716374016, ISRC ""
    2: TRM_DATA_MODE1, 2048/0x00, FilePos 716374016 716374016 716376064, ISRC ""
    DAO layout:
    __Start_|____Track_|_Idx_|_RecDep_|_CtrlAdr_
    0 | lead-in | 0 | 0x00 | 0x41
    0 | 1 | 0 | 0x00 | 0x41
    0 | 1 | 1 | 0x00 | 0x41
    349792 | 2 | 0 | 0x00 | 0x41
    349792 | 2 | 1 | 0x00 | 0x41
    349793 | lead-out | 1 | 0x00 | 0x41
    3:03:28 PM #16 Phase 24 File dlgbrnst.cpp, Line 1855
    Caching of files started
    3:03:28 PM #17 Text 0 File Burncd.cpp, Line 4183
    Cache writing successful.
    3:03:28 PM #18 Phase 25 File dlgbrnst.cpp, Line 1855
    Caching of files completed
    3:03:28 PM #19 Phase 36 File dlgbrnst.cpp, Line 1855
    Burn process started at 4x (5,540 KB/s)
    3:03:30 PM #20 Text 0 File ThreadedTransferInterface.cpp, Line 2344
    Verifying disc position of item 0 (relocatable, disc pos, no patch infos, orig at #0): write at #0
    3:03:30 PM #21 Text 0 File ThreadedTransferInterface.cpp, Line 2344
    Verifying disc position of item 1 (relocatable, no disc pos, no patch infos, orig at #0): write at #0
    3:03:30 PM #22 Text 0 File Cdrdrv.cpp, Line 8128
    ---- DVD Structure: Physical Format Information (00h) ----
    Layer: 0, Address: 0 (0 h), AGID: 0; Length: 2050
    Book Type: DVD+RW (9), Part Version: 2
    Disc Size: 120 mm, Maximum Rate: <not specified> (F h)
    Number of Layers: 1, Track Path: Parallel Track Path (PTP), Layer Type: re-writable
    Linear Density: 0,267 um/bit, Track Density: 0,74 um/track
    Starting Physical Sector Number of Data Area: 30000 h (DVD-ROM, DVD-R/-RW, DVD+R/+RW)
    End Physical Sector Number of Data Area: 5A9FF h
    End Sector Number in Layer 0: 0 h
    Data in Burst Cutting Area (BCA) does not exist
    Disc Application Code: 0 / 0 h
    Extended Information indicators: 1 h
    Media type ID: W11
    Number of Physical format information bytes in use in ADIP up to byte 63: 57
    Media Specific [16..63]:
    00 00 01 52 49 43 4F 48 - 4A 50 4E 57 31 31 01 39 ...RICOHJPNW11.9
    23 00 8A 86 68 02 26 00 - 8A 86 70 02 28 00 8A 86 #...h.&...p.(...
    6A 02 28 22 12 10 E0 00 - F0 00 00 00 00 00 00 00 j.("............
    3:03:30 PM #23 Text 0 File dlgbrnst.cpp, Line 1713
    Set remaining time: 3:27,228 (207228ms) -> OK
    3:03:30 PM #24 Text 0 File DVDPlusRW.cpp, Line 628
    Start write address at LBA 0
    DVD high compatibility mode: Yes
    3:04:54 PM #25 SCSI -300 File Cdrdrv.cpp, Line 1442
    SCSI Exec, HA 1, TA 0, LUN 0, buffer 0x02A60000
    Status: 0x04 (0x01, SCSI_ERR)
    HA-Status 0x0E (0x08, SCSI_HASTAT_BUS_RESET)
    TA-Status 0x00 (0x00, OK)
    Sense Key: 0x00 (KEY_NO_SENSE)
    Sense Code: 0x00
    Sense Qual: 0x00
    CDB Data: 0x2A 0x00 0x00 0x00 0x83 0x80 0x00 0x00 0x20 0x00 0x00 0x00
    Sense Data: 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00
    3:04:54 PM #26 CDR -300 File Writer.cpp, Line 304
    Unspecified host adapter error
    SONY DVD RW DRU-510A\H1 T0
    3:04:54 PM #27 Text 0 File ThreadedTransfer.cpp, Line 229
    all writers idle, stopping conversion
    3:04:54 PM #28 Text 0 File ThreadedTransfer.cpp, Line 223
    conversion idle, stopping reader
    3:04:55 PM #29 SCSI -1114 File Cdrdrv.cpp, Line 1188
    HA-Status 0x00 (0x00, OK)
    TA-Status 0x02 (0x01, SCSI_TASTATUS_CHKCOND)
    Sense Key: 0x06 (KEY_UNIT_ATTENTION)
    Sense Code: 0x29
    Sense Qual: 0x00
    CDB Data: 0x35 0x02 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00
    Sense Data: 0x70 0x00 0x06 0x00 0x00 0x00 0x00 0x12
    0x00 0x00 0x00 0x00 0x29 0x00
    3:04:55 PM #30 Text 0 File dlgbrnst.cpp, Line 1713
    Set remaining time: 0:00,000 (0ms) -> OK
    3:04:55 PM #31 CDR -1114 File WriterStatus.cpp, Line 164
    Reset occurred
    3:04:55 PM #32 TRANSFER -24 File WriterStatus.cpp, Line 164
    Could not perform end of Disc-at-once
    3:04:55 PM #33 Text 0 File dlgbrnst.cpp, Line 1713
    3:04:55 PM #34 Phase 38 File dlgbrnst.cpp, Line 1855
    Burn process failed at 4x (5,540 KB/s)
    Existing drivers:
    File 'IoSubSys\SCSI1HLP.VXD': Ver=4.90.3000, size=19278 bytes, created 6/8/2000 5:00:00 PM
    File 'IoSubsys\NEROCD95.VXD': Ver=4.5.0.14, size=39882 bytes, created 3/11/2002 11:55:38 AM
    File 'IoSubsys\CDR4VSD.VXD': Ver=2.5 (089), size=197984 bytes, created 3/2/2001 8:55:54 PM
    File 'IoSubsys\CDRALVSD.VXD': Ver=1.00 (1030), size=20047 bytes, created 3/2/2001 8:55:54 PM
    File 'IoSubsys\ACBHLPR.VXD': Ver=1.01, size=40508 bytes, created 3/2/2001 8:55:54 PM
    File 'IoSubsys\asapi.vxd': Ver=5, 1, 0, 2, size=14581 bytes, created 3/11/2004 2:49:00 PM
    File 'IoSubsys\CDFS.VXD': Ver=4.90.3000, size=59141 bytes, created 6/8/2000 5:00:00 PM
    File 'IoSubsys\ESDI_506.PDR': Ver=4.90.3000, size=25365 bytes, created 6/8/2000 5:00:00 PM
    File 'IoSubsys\USBMPHLP.PDR': Ver=4.90.3000, size=4861 bytes, created 6/8/2000 5:00:00 PM
    File '..\System32\Drivers\1394bus.sys': Ver=4.90.3000.1, size=44240 bytes, created 6/8/2000 5:00:00 PM
    File '..\System32\Drivers\Ohci1394.sys': Ver=4.90.3000.1, size=49488 bytes, created 6/8/2000 5:00:00 PM
    File '..\System32\Drivers\Sbp2port.sys': Ver=4.90.3000.1, size=36336 bytes, created 6/8/2000 5:00:00 PM
    File 'IoSubsys\Disktsd.vxd': Ver=4.90.3000, size=18663 bytes, created 6/8/2000 5:00:00 PM
    File 'IoSubsys\USBMPHLP.PDR': Ver=4.90.3000, size=4861 bytes, created 6/8/2000 5:00:00 PM (Adapter driver for rec)
    File 'IoSubsys\ESDI_506.PDR': Ver=4.90.3000, size=25365 bytes, created 6/8/2000 5:00:00 PM (Adapter driver for src)
    Registry Keys:
  22. Ulead Videostudio or Pinnacle Studio can capture,convert and burn with WinMe.
    VideoStudio can even make menus and chapters,it has a 30 day free trial.
    BTW..use a DVD/RW for testing.
  23. Member
    Aug 2004
    i get this error
    its a USB sony DRX-510UL
    i get this error abotu 2 minutes into burning the dvd with nero
    "windows cannot access the specificed device ,path or file , you may not have the appropriate permissions to access the item"
    how can i fix this?
    the thign is if if a put an cd or dvd movie it spits out that message......
    BUT if i manually goto the drive with windows explorer i can run the cd that way
    or open my dvd player and play the movie that way
    what could this be a problem of?
  24. Member
    Aug 2004
    i think this has something to do with my home network
  25. Member
    Aug 2004
    i noticed something in my device manager in the cd rom section the sony is there but when i look for the driver it isnt there
    but it seems to work for the most part without it
    except for burning
    can anyone help me with this problem?
  26. Member
    Aug 2004
    the driver is there now
    when i burn with nero which DVD setting do i choose?
    dvd-video, dvd roo udp, dvdrom iso?
  27. The "unspecified host adapter error" could be a lot of things. Uninstall, remove all software and drivers, re-install in correct sequence, then use software designed for the drive. The windows "cannot access" error also could be many things. Above procedure should fix it, also make sure you have Administrator rights. It also could be defective, it is a refurb, after all.
    You stated you had successfully burnt a data file to a DVD. What software did you use? Suggest using same to burn.
    The authoring programs will produce the correct files and structure for your VCD-DVD. Stick with what works.
    Side note - MPEG-1 on DVD allows a bitrate of up to 1850. Not sure if this is mandatory. VBR usage may be allowed. 48k audio is required. These are significant deviations from VCD specs.
    As mentioned, get some RW disks.
