Hi All,
I am using ffmpeg to convert my dv video to DVD Video. For the same I
have used following command:
ffmpeg -i INPUT/0000.avi -vcodec mpeg2video -r 25 -s 704x576 -b 5000
-ab 224 -ar 48000 -ac 2 -hq -deinterlace 0000.mpg
$ ffmpeg -i INPUT/0000.avi -vcodec
mpeg2video -r 25 -s 704x576 -b 5000 -ab 224 -ar 48000 -ac 2 -hq
ffmpeg version 0.4.8, build 4717, Copyright (c) 2000-2004 Fabrice Bellard
built on Jul 8 2004 17:14:40, gcc: 3.3.3 20040412 (Red Hat Linux 3.3.3-7)
Input #0, avi, from 'INPUT/0000.avi':
Duration: 00:14:30.4, bitrate: 29829 kb/s
Stream #0.0: Video: dvvideo, 720x576, 25.00 fps
Stream #0.1: Audio: pcm_s16le, 32000 Hz, stereo, 1024 kb/s
Output #0, mpeg, to '0000.mpg':
Stream #0.0: Video: mpeg2video (hq), 704x576, 25.00 fps, q=2-31, 5000 kb/s
Stream #0.1: Audio: mp2, 48000 Hz, stereo, 224 kb/s
Stream mapping:
Stream #0.0 -> #0.0
Stream #0.1 -> #0.1
Press [q] to stop encoding
AC EOB marker is absent pos=640kB time=127.0 bitrate=5248.1kbits/s
AC EOB marker is absent pos=68
frame= 7172 q=3.4 Lsize= 183604kB time=286.0 bitrate=5259.8kbits/s
video:175075kB audio:7819kB global headers:0kB muxing overhead 0.388311%
The problem that is coming up is that I dont have the full length video
in the output file. The length of input file is 14:30 min, but that of
output file is around 4:46 mins only. Any clues as what may be happening
here?
TIA.
-McLinux
[/b]
Closed Thread
One thread is enough.
https://www.videohelp.com/forum/viewtopic.php?t=229700You are in breach of the forum rules and are being banned. Do not post false information.
/Moderator John Q. Publik
Encode with FFMPEG with multiple input files...
By RogerTango in forum Video ConversionReplies: 3Last Post: 20th Jun 2011, 01:12 -
Padding Audio to match Video Length with FFMPEG?
By boyer in forum Video ConversionReplies: 0Last Post: 31st May 2010, 10:13 -
Burning 10 full length vids into a DVD9
By maggot6sic6 in forum Newbie / General discussionsReplies: 18Last Post: 23rd May 2008, 23:06 -
FFMPEG and input A/R
By nic2k4 in forum Video ConversionReplies: 1Last Post: 14th Nov 2007, 19:39 -
Burning vcd/svcd full length film.........
By marcgarcia in forum Authoring (VCD/SVCD)Replies: 2Last Post: 15th Oct 2007, 20:07
