I would like to know which program i should use to convert a movie from widescreen to a full screen movie?I would prefer a quality program for doing this?
I think you'll have a tough time emulating professional "Pan and Scan." Check this out: http://www.widescreen.org/index.shtml
If you're still up for it, I'm sure several suggestions will be posted for you. Good Luck!If God had intended us not to masturbate he would've made our arms shorter.
George Carlin -
What kind of file is it? and what are you doing with it? do you just want to have a fullscreen file, or are you trying to convert it to dvd?
Hello,
You could try tmpgenc. Load the dvd template and insert your source file. Then go to the setting tab - select advanced - select full screen from [video arrange method].
Though I agree with Shocker Milwaukee, you won't get a "true" full screen out of it. I've watched dvd's on a computer with the full screen option in powerdvd. It automatically zooms in to the middle of the movie. So everything on the extreme left and right will be left out. (especially disturbing on the really wide 2.35:1 movies - like star wars, lord of the rings, etc...).
Kevin
P.S. That is what "Pan and Scan" means. They actually slide the screen around to capture the key elements. Sometimes they'll cut straight to the left or right to focus on the speaker. That's why movie buffs like me only buy widescreen, even those of us with wimpy 25" non hdtv setsDonatello - The Shredder? Michelangelo - Maybe all that hardware is for making coleslaw? -
my own preference involves playback. there are several dvd players, example, almost all panasonic's, which allow incremental zoom, in panny' case 1% increments. that way if you do have a widescreen film, espcially something like 2.35:1 on a smaller screen. you can zoom to say 120% and have a good compromise. Of course that is a playback option and perhaps not applicable to your situation.
You will loose about 1/3 of the picture by converting it to full screen, people will be cut out of a conversation and it will look horrible. As suggested, it's better to convert it to wide screen and then use the zoom on your player if you wish.
Full Screen Ripped DVD is not Displaying Full Screen on Widescreen TV
By jgciamarra in forum DVD RippingReplies: 3Last Post: 23rd Jan 2012, 17:42 -
Windows Media Player 8 full screen DVD playback not full screen
By brassplyer in forum Software PlayingReplies: 1Last Post: 3rd Jan 2012, 15:43 -
Blank screen when playing video on 'full screen'
By RAYPEV in forum Newbie / General discussionsReplies: 6Last Post: 4th Aug 2011, 19:40 -
DVD Lab Pro, help mixing full screen and wide screen.
By stantheman1976 in forum Authoring (DVD)Replies: 4Last Post: 31st May 2009, 17:23 -
How can I convert a widescreen movie to full screen movie on PSP?
By VidHunter in forum MacReplies: 2Last Post: 9th Nov 2008, 22:20
