    Oct 2003
    Manchester, UK
    Managed to copy my files from VCR to my pc. Then converted them to MPeg2 ready for VCD.
    So .. What prog do people reccomend for buring them to CDR? Don't want anything too fancy, just something to stick a title on really.
    May 2003
    Pal Realm
    Probaby most popular is VCDEasy. It's in the Tools section on the left.
    But... VCD should be mpeg1 :c* Is that what you have?
    There's no place like 127.0.0.1
    The Rogue Pixel: Pixels are like elephants. Every once in a while one of them will go nuts.
    Oct 2003
    Manchester, UK
    Actually, I want to burn as SVCD, hence Mpeg2 - which I believe is right??
    May 2003
    Pal Realm
    Yes that's right. :c) Above you said vcd.
  5. basic title, you can use nero or nero express. If that doesnt work for you, try recordnowmax. You'll hear good and bad about both of them.
