Anyone agree with me?
There is only one thing that bothers me about mini Dv camcorder. Picking up motor noises.
I believe there is a reason why most professional camcorders use tape as a media.
I'm on the market for new HD camcorder. After considering of buying SDHC card cam, I'm back on the track to go with mini DV.
Canon HV30 so far is my choice.
cheers
J
only drawbacks to the canon hv cams are battery life and the built in mic. make sure you buy a couple large extras batteries. and consider an add-on shotgun mic. other than that i like my hv30 quite a bit.
Gotta concur with mindv2dvd. Pros don't worry about motor noise because pros don't use the built-in mics. All my minidv tapes have lasted longer than my hard drives and memory cards.
Originally Posted by minidv2dvd
"motor noise" is more noticeable when using automatic gain control (AGC) camcorders. When things get quiet, the AGC pumps up the gain and you hear the motor.
Buy only camcorders with manual audio level override. Set audio for the loudest expected audio and leave it there. Then fix gain in post. The HV20/30 have manual audio control.
BTW, I agree on HDV. AVCHD needs a digital intermediate codec to favorably compare.Recommends: Kiva.org - Loans that change lives.
http://www.kiva.org/about -
Originally Posted by edDV
I was getting far better audio out of the on-board mics on my S-VHS-C camcorder nearly two decades ago!
Cheers,
David. -
I have long been using a SONY DCR HC42E DV Camcorder, but I have never seen that it is picking up any motor noise. But I do agree that tape is still the professional choice because IMO the quality of captured media still very high.
আমি বাংলায় গান গাই
How to Cut & Merge mini 10 part mini series?
By skorpinok in forum EditingReplies: 5Last Post: 8th Oct 2011, 09:41 -
Capture progressive mini-dv tape on interlaced mini-dv cam ?
By alip in forum Capturing and VCRReplies: 4Last Post: 8th Feb 2011, 17:27 -
What is the deal with the f**king windowboxing?!?!?!
By explosionfoot in forum ffmpegX general discussionReplies: 9Last Post: 20th Apr 2009, 13:25 -
Hardware choices: standalone mini-DV deck, or cheap mini-dv camera?
By SgtRauksauff in forum Newbie / General discussionsReplies: 3Last Post: 14th Oct 2008, 02:18 -
Hd Mini dv tapes via SD mini DV camcorder
By imptech3 in forum Newbie / General discussionsReplies: 1Last Post: 13th Jul 2007, 02:11
