Results 1 to 25 of 25
  1. Some of our German colegues started to work on Video Plugins for Pinnacle Studio version 9. This is new funcionality of Studio 9. Pinnacle makes SDK available so anybody can create new cool Plugin's.
    Get Pinnacle's RTFX and VST SDK
    I will add more Plugins if I find them.... I will not judge quality.
  2. MIRROR: Version 1.1
    ORIGINAL
    VERTICAL - COMPLETE FRAME
    VERTICAL - LEFT FRAME SIDE
    VERTICAL - RIGHT FRAME SIDE
    HORIZONTAL also available but no pictures here
  3. JPsEffects 0.2
    MIRROR (VERTICAL + HORIZONTAL)
    ZOOM
    ZOOM AND MOVE
    STRETCH ZOOM
  4. New one... more info later (I am busy)
    huecycle-Filter
    This filter cycles the hues of an image as the frame number increases. The number of frames per cycle can be changed.
  5. Two new Plug-In's....
    MULTIPLE Video Plugin and HOTSPOT Video Plugin
    So far I have no idea what they do.... It's getting harder to keep informed..
  6. Some more...
    MikeSoft's Invert Video Plugin. More will be available when 9.1 version is released.
    What author is saying about his plugins
    Originally Posted by Mikeysoft
    ...my plugin also has flip/mirror and renders faster then most other plubins
    INVERT
    MIRROR (FLIP) HORIZONTAL
    MIRROR (FLIP) VERTICAL
    Jul 2002
    Boston, MA
    You forgot to add that my plugin also has flip/mirror and renders faster then most other plubins.
    Visit my web site at http://home.comcast.net/~m.mikeysoft for my latest video effects for Pinnacle Studio 9.
  8. donpedro, you are doing a great job with this. I noticed this on the huecolor plugin, the creator now has a addframenumber plugin which works great. Many users have been wanting the ability to put the frame number and time of the clip on the video, well they can do it now...
    http://www.hlinke.de/RTFX-Plugins/RTFX_Plugin__E_/rtfx_plugin__e_.html
    http://www.hlinke.de/RTFX-Plugins/RTFX_Plugin__E_/rtfx_plugin__e_.html]add frame number
  9. AddFrameNumber v0.2
    Add the framenumber, timecode and date/time to a frame
    In current version you can display 3 different values.
    - left top : current date and system time when video clip was encoded (sorry... not date and time when video was captured) this have one side effect. Since encoding is slower then real time, time is running faster
    - left bottom : time information from clip. each clip starts from 00:00:00.XX (XX is frame number within one second)
    - right side : frame number of clip
    clip = clip in Pinnacle's meaning. So if you need somethink that goes across more clips and still continues countin, you need to combine them first (make avi or something)
    So here are print screens....
  10. http://home.t-online.de/home/klaus.horst/hobby/pins9vplugins.htm#Anker8997
    Studio 9 HOTSPOTMOVE Video Plugin
    Studio 9 REVERSE Video Plugin
    Pictures and comments later
  11. There is so much good stuff out there for free, it's difficult to justify paying for things unless you really get a lot for your $.
  12. Will the plug-ins work in both NTSC & PAL?
  13. Originally Posted by billcurrie
    Good question. I have no idea. There are two ways to find out. Try or ask developer
  14. Two new...
    Radial Lum Corrector (Correction of hotspots created by Super 8 projectors)
    RGB-Filter (separate control of red, green and blue color)
    http://www.hlinke.de/RTFX_Plugins/RTFX_Plugin__E_/rtfx_plugin__e_.html
    http://www.hlinke.de/RTFX_Plugins/RTFX_Plugin__E_/RGB-Filter/rgb-filter.html
  15. DVTimeDate - is this going to be the one that I am realy looking for ? Let's wait for real test
  16. Looking for a plugin to do black and white and only color on certain objects you wanted.. anyone know of any? Example a kid holding an apple, everything is in black and white, except for the apple.
    Thanks for all the help
  17. Try HOTSPOT. It might do it in some extent.
  18. Thanks for the tip!
  19. Thanks for sharing these guys. Is it WRONG that I'd often rather see what I can do in Pinnacle Studio 9 or Ulead MovieFactory than fire up Premiere or Vegas Video
  20. My DV-camera (Panasonic NV-GS 3) doesn’t support true widescreen. Instead it ads black fields in the top and in the bottom. As Pinnacle Studio 9 only supports true widescreen I cannot take advantage of this feature.
    I wonder if anyone knows of a crop plugin that can remove the black fields?
    May 2003
    Must be in Heaven....
    Hi !
    Just a question. Is anyone familiar with the next problem ?
    On a P4p800E-deluxe with P4 3.2 Ghz P4 ht proc. and 1 gig internal memory an 4 S-ata drive's in striping mode This software should run quit good.
    But if i install Pinnacle 9 deluxe it causes some heavy payload on the system causing real slow output.
    Is it possible that the use of an extended desktop is causing these missery ? There are no hardware problems . Even the Movie-Box Deluxe from Pinnacle is working here also no hardware problems.
    System itself is running WinXp-Pro with Sp2. Everything licenced !
    Who can help out !
    P.s. System is fresh installed, and contains only office Xp.
    Nothing else....
    Please help out...
    I. Am Cornholio. Love to see my Bugaloo....
    Now the beer has evolved to an higher level.
    Keep up the news on the forum ?... hihi.... :oops
  22. You may be better off looking for help with Studio 9 Here
    Geronimo
  23. Member
    May 2003
    Thasnks redd Download some stuff.
    Mightbe a solution. many thanks, for the given effort !
    Greetz Bigfoot !!!
    (Geronimo )
