Forum archive - Xvid4PSP
http://www.supermediastore.com/
Forum Archive Home -> Newbie / General discussions -> Xvid4PSP
Xvid4PSP
kumar66 posted 2009 Oct 31 17:46
Hey all,
I just installed Windows 7 Ultimate and I was wondering why Xvid4PSP is now having issues with the audio. Every time I put a video up to convert and I test it out, the video plays with pixel marks and the audio is playing at super speed. Is there any requirement for proper functioning that I am missing. I installed Xvid4PSP 5.0.37.5 r2 (unofficial). Using the avisynth it has and everything else it has, then I installed the K-Lite Mega codec pack. Is it a net framework issue? or something else? any help would be appreciated.
Baldrick posted 2009 Oct 31 19:14
I have no problems with it under win7 ultimate. But then I haven't installed any klite pack...
Do you get same problem whatever video source, profile and setting you use?
Or maybe time to try something else, like HandBrake!
kumar66 posted 2009 Oct 31 20:45
Yeah no matter what setting I use it does the same thing. The volume is sped up. :/
yoda313 posted 2009 Oct 31 20:46
Do you mean the audio is sped up?
Are you trying to convert a pal video to ntsc? Could that be the issue?
kumar66 posted 2009 Oct 31 20:55
Yes, sorry I mean the audio is sped up and no, I am trying to convert an MKV into a MP4 for psp use. It used to work perfectly before I switched to windows 7 and then it just stopped working...is it cause i am missing Microsoft Net Framework? Or DivX or something?
PS3_Advance posted 2009 Nov 01 03:32
I had the same issue too on my Win 7 P.C, the audio was very fast. I tried it with the Windows XP Virtual mode, and it was fine. It must be a compatibility issue with 7, MS .Net Framework 3.5 is installed by default with Windows 7 and since it has a large codec pack (with the exception of .mkv) divx is not missing.
I'm currently running the previous "official" version 5.036 with no audio issues.
lordsmurf posted 2009 Nov 01 03:41
Codec packs are usually the problem.
Baldrick posted 2009 Nov 01 04:03
You can try the old versions, download from http://www.videohelp.com/tools/XviD4PSP/old-versions#download
kumar66 posted 2009 Nov 01 08:22
Thank you all for your suggestions! I just installed the virtual XP mode and am currently using that with no issue. Thanks again for all the suggestions and taking the time to offer me some help. :)
Login/Register to our forum to be able to post here.
DVDFab DVD to DVD and Blu-ray to Blu-ray offers a 20% discount until Nov 22, 2009. More info or download trial!
About   Advertise   Forum Archive   RSS Feeds   Statistics
