Forum archive - Wrinkled lines aka wiggles in my S-VHS caps, help!
http://www.supermediastore.com/
Forum Archive Home -> Restoration -> Wrinkled lines aka wiggles in my S-VHS caps, help!
veedeo posted 2009 Sep 12 01:16
Hello.
I am using a JVC HR-S5980 to transfer S-VHS tapes to my computer and am having the following problem illustrated in the picture below.
I have tried with and without my AVT-8710 TBC and have the issue both ways.
I am capturing to Huffyuv using a Philips SAA713X based capture card but I don't think the capture card is the issue.
From reading other posts, people mention a "line level TBC" could fix this. What exactly is that? Do I need to get another VCR with a built-in TBC or can I get an external "line level" TBC? Will this even fix the problem?
Your help is greatly appreciated.
-veedeo
lordsmurf posted 2009 Sep 12 01:33
"need to get another VCR with a built-in TBC"
That's it.
Or use a Panasonic ES10/ES15 as a "passthrough" filter.
veedeo posted 2009 Sep 12 02:23
Thanks for confirming this.
I'll try the Panasonic route first and see how it goes.
-veedeo
jagabo posted 2009 Sep 12 08:31
ES15 example: http://forum.videohelp.com/topic369003.html#1975151
veedeo posted 2009 Sep 12 18:14
That looks great. I can't wait to get my hands on one of those and try it out.
This wiggle is very distracting when watching the video. It's a lot more noticeable when capping S-VHS tapes than VHS.
-veedeo
jagabo posted 2009 Sep 12 18:26
You'll get much better compression with the TBC corrected video too.
veedeo posted 2009 Sep 22 01:15
jagabo,
Do you know if the ES18 provides the same TBC goodness?
I don't know what to look for in the specs. Nothing mentions TBC:
http://www.bhphotovideo.com/c/product/620022-REG/Panasonic_DMR_ES ... e_DVD.html
I'm just wondering if this is an alternative to the ES15.
-veedeo
lordsmurf posted 2009 Sep 22 04:58
None of them have TBCs inside, that is why. They do have basic frame synchronization, but it's a far cry from a full fledged TBC. The frame sync used by the specific Panasonics mentioned is what you want anyway.
I don't know about the ES18, sorry. There are some members here, however, who should.
Login/Register to our forum to be able to post here.
Replay Media Catcher lets you record ANY streaming video and save on your computer! More info or download trial!
About   Advertise   Forum Archive   RSS Feeds   Statistics
