Forum archive - Wireless PC to TV devices
http://www.supermediastore.com/
Forum Archive Home -> Media Center PC / MediaCenters -> Wireless PC to TV devices
jrmy_1 posted 2009 Aug 22 17:13
I'm looking to play videos, pics, etc. from my PC to TV. My PC is quite a distance from my TV so I wanted to go with a wireless system but I'm not sure what is best in terms of picture quality and a few reviews I read said they had less than acceptable picture quality.
I thought maybe use my laptop, buy I only have an SVGA output and I've read the cables from SVGA to HDMI also have a blurry picture, so I thought maybe a DVD player that would play multiple formate. Then I read reviews and it said that it's hard to find a device that is able to play multiple formats and it is better to use a computer.
Now I'm back to a wireless PC to TV device if there are any out there that are reliable, good picture and don't cost an arm and a leg.
Any recommendations out there?
Thanks,
J
SingSing posted 2009 Aug 22 21:51
You need a media PC or laptop.
There are many discounted media PCs on the cheap like this one:
http://www.geeks.com/details.asp?invtid=WSYS195N-PB&cat=SYS
jrmy_1 posted 2009 Aug 22 22:14
My desktop has HDMI, but my laptop doesn't. I would still need a wireless PC to TV network as my TV is in another room from my PC.
rallynavvie posted 2009 Aug 22 23:22
Any wireless media center extenders are going to cost almost as much as buying a basic HTPC so the choice is yours. I'd prefer the full HTPC. I think there's a long thread about a WD one in this forum.
jrmy_1 posted 2009 Aug 23 09:57
I'll look into it. I may be better off just buying a wireless television as I plan to in a few months. Thanks for the help!
jagabo posted 2009 Aug 23 10:27
Something like this?
http://www.amazon.com/Terk-Technologies-Leapfrog-LF-30S-Distribut ... B00009UHXR
http://www.amazon.com/Wireless-Broadcast-Transmitter-Receiver-Inf ... B000GJKV9A
yoda313 posted 2009 Aug 23 12:05
Do you already own a xbox 360 or playstation 3? If so you already have all you need to network to the pc. The ps3 has built in wireless. The xbox 360 needs a pricey adapter for one - or you can get a generic wireless add on so long as it specifically states it works with the 360. From there you can use windows media player or tversity to stream.
Just be aware that video streamed wirelessly can lag and stutter. I know this is true for wireless G. I don't have N yet so I don't know if the extra bandwidth makes that much of a difference.
Of course dlink makes devices you can check into if your not into gaming.
SingSing posted 2009 Aug 23 22:16
jagabo :
Isn't these only transfer old composite signals ?
jagabo posted 2009 Aug 23 22:24
SingSing :
jagabo :
Yes, he'd have to have composite or s-video out on his computer.
Login/Register to our forum to be able to post here.
VSO Software ConvertXtoDVD lets you convert any video like AVI,MKV to DVD easily. More info or download trial!
About   Advertise   Forum   Forum Archive   RSS Feeds   Statistics   Tools
