Forum Archive Home -> VCDEasy General -> Why no audio on SVCD?
Why no audio on SVCD? |
| dphirschler posted 2005 Jul 12 13:07 |
| So, I authored my SVCD like I always have... encoded in TMPEGenc using the standard film SVCD template with the external Lame encoder for audio. The resulting mpg plays fine (with audio) in VLC. I authored and burned my SVCD in VCDeasy, no menu, three chapters.
Why is it that my resulting SVCD has no audio?? Specifically, the SVCD I authored plays fine but without audio on all my standalone players as well as my PC. Also, I have not had a problem creating VCDs in the same manner. Yes, I have changed many things on the PC since I authored my last SVCD. In fact, I think it is by now a completely new PC. And the version of VCDeasy is newer. I am now using the latest freeware version instead of one a few versions back from that. Is this a known bug or have I set something up wrong? Darryl |
| wolleric posted 2005 Jul 14 08:14 |
| maybe your input audio has a sampling rate of 48kHz but your standalones only accept the official SVCD standard (44.1kHz). don't know if TMPGEnc has some kind of SSRC feature as i always use CCE but you might want to check. if your audio is 48kHz, use BeSweet or so to resample it. |
| dphirschler posted 2005 Jul 14 08:43 |
| I am prety sure the audio is 44.1, but I will double-check it. The VCD (from the same source files) plays just fine.
Darryl |
Login/Register to our forum to be able to post here.
