Forum Archive Home -> Media -> What's the difference between YUDEN000 T02 and YUDEN00 T02?
| What's the difference between YUDEN000 T02 and YUDEN00 T02? | ||
| Xybernauts posted 2008 Oct 05 23:21 | ||
| I want to purchase Taiyo Yuden media with the code YUDEN000 T02. According to a poll at http://club.cdfreaks.com/f33/cdfreaks-most-popular-dvd-mediacodes-247164/ and a number of other sources these are some of the best media you can buy. I also know you have to watch out for fakes.
On www.meritline.com they have Taiyo Yuden media with the code YUDEN00T02. Notice the code YUDEN00T02 only has only two 0's after the YUDEN and before the T02. Below is from http://www.meritline.com/taiyo-yuden-8x-dvd-plus-r-silver-thermal.html
Most sources suggest there is supposed to be three 0's. Does the variation between two or three 0's in the Taiyo Yuden media code make a difference or are they the exact same media? | ||
| FulciLives posted 2008 Oct 05 23:37 | ||
| I only buy Taiyo Yuden from RIMA.COM and I only buy DVD-R as I am philosophically opposed to DVD+R discs.
My main point though is this: you won't be getting fake Taiyo Yuden from RIMA.COM - John "FulciLives" Coleman P.S. The last batch I bought from RIMA.COM are the Taiyo Yuden 8x DVD-R discs with the "Silver Lacquer (Shiny Silver)" surface. The code reads: TYG02 | ||
| lordsmurf posted 2008 Oct 05 23:53 | ||
| I'm sure its just a typo. The actual code is YUDEN000T02 and there's actually a space in there somewhere too. The media ID software can vary a tad too. |
Login/Register to our forum to be able to post here.
