Forum archive - what pc spec is needed for blueray burner
http://www.supermediastore.com/
Forum Archive Home -> DVD & Blu-ray Writers -> what pc spec is needed for blueray burner
volam posted 2009 Sep 26 10:29
I was looking to buy a bd burner on Amazon.com. This item requires a PC with dual core, 1gd memory, ATI HD 2000, Nvidia video card... Meanwhile other bd burners doesn't even mention about PC reqiurements. My question is what kind of computer I need to have? Thank you
Dr_Layne posted 2009 Sep 26 10:36
The PC requirements are to run the included software package. You need a decent processor, ram, and video card to play BD discs and to edit HD video.
At the minimum a dual core cpu, 2GB of DDR2 ram and a HD video card should be considered.
volam posted 2009 Sep 26 10:48
If I just want to put multiple dvd movies on a bd disc, I definitely need a bd burner. Do I still need a HD video card? If so can you name some hd video cards? Thankyou.
MOVIEGEEK posted 2009 Sep 26 11:52
You don't need an HD videocard to author but you do to output to an HDTV, I would consider these:
http://www.newegg.com/Product/Product.aspx?Item=N82E16814121320
http://www.newegg.com/Product/Product.aspx?Item=N82E16814102829
If you can afford a new PC I would wait one month to get one with Win7, I also read Apple is coming out with a Mac with Blu-ray.
Login/Register to our forum to be able to post here.
VSO Software ConvertXtoDVD lets you convert any video like AVI,MKV to DVD easily. More info or download trial!
About   Advertise   Forum Archive   RSS Feeds   Statistics
