Hi,
I know most questions are about copying FROM HDD to DVD , I would like to do the reverse ...
I own a samsung DVD-HR 725 ( 160 gig ) and I would like to transfer clips from my PC to the samsung HDD recorder ...
When I author and wright with NEROVISION ( of course in VR MODE ) , the dvd's are read but halt every 2 seconds ( you can see the counter going bananas ) ... however, it plays perfectly in the smaller TITLE window ...
What setting or method do I have to change ?
tnx
Guy
VideoHelp is littered with posts from members who tell us Nero is a very poor authoring tool that creates problematic DVDs. More than likely you will get better disc compatibility from ULead or any other DVD recording application.
However you should know that almost all DVD/HDD recorders "lock out" DVDs made on other recorders or on PCs, even in VR mode. They aren't as versatile in reading DVD formats as a PC, which is why you can make use of your Samsung recordings on your PC but cannot go easily in the other direction. The recorder will usually not high-speed copy the DVD from your PC onto its hard disk without transcoding it or otherwise interfering with it. I have been able to do this by moving VR DVDs within different models of the same brand recorder (Pioneer), but not with DVDs from my PC. A lot depends on the brand and model of DVD/HDD recorder: Samsungs are not that common in the USA, perhaps a member from Europe has a workaround and will post it for you here.
Reading HDD from HDD recorder on Windows XP
By mvidelgauz in forum Newbie / General discussionsReplies: 12Last Post: 18th Apr 2011, 03:51 -
Copying from standalone hdd recorder's hdd to pc hdd
By flez in forum ComputerReplies: 7Last Post: 6th Dec 2010, 07:17 -
HDD Recorder Only
By wulf109 in forum DVD & Blu-ray RecordersReplies: 12Last Post: 10th Jun 2010, 20:06 -
PC HDD Driver for Panasonic DVD Recorder HDD
By SG-01 in forum DVD & Blu-ray RecordersReplies: 9Last Post: 30th Aug 2007, 04:54 -
Toshiba RD-KX50 DVD Recorder / HDD Recorder
By Kinddomaker in forum DVD & Blu-ray RecordersReplies: 2Last Post: 2nd Jul 2007, 22:19
