Forum Archive Home -> SVCD2DVD General -> VOB2MPG 2.5 Finished processing 0 vobsets. Duration 00:00:00
| VOB2MPG 2.5 Finished processing 0 vobsets. Duration 00:00:00 |
| d4d9d4 posted 2008 Jun 20 16:07 |
| Dear Chrissboy - I must first, extend my best wishes, to your wonderful software. I absolutely think it is the fastest and easiest conversion software I have found thus far.
I am experiencing a problem with trying to convert a DVD on the harddisk to usable .mpg files. It says :Finished processing 0 vobsets. Duration 00:00:00 . I can not find the c:\Program Files (x86)\BaderIT\Log folder? Ideas, Vista64Ultimate running v2.5 and trying to encode SM ALL VILLE_SEASON_1_DISC_1 ? (I even tried to create a \Log and \Logs and nothing was written to it) Your software has worked for me on the other DVD's, so I seem to have a stubborn one. If I open a .vob in WMP, it will eventually allow me to find the root menu, so i think that my rip has been successful. I would appreciate your thoughts - the directory sturcture... ( there are no spaces in directory name between M and A and L and V -just want to fool the web crawlers ;-) ) C:\SM ALL VILLE_SEASON_1_DISC_1\VIDEO_TS>dir Volume in drive C has no label. Volume Serial Number is A800-BD64 Directory of C:\SM ALL VILLE_SEASON_1_DISC_1\VIDEO_TS 06/20/2008 03:08 PM <DIR> . 06/20/2008 03:08 PM <DIR> .. 06/20/2008 02:50 PM 10,240 VIDEO_TS.BUP 06/20/2008 02:50 PM 10,240 VIDEO_TS.IFO 06/20/2008 03:08 PM 147,456 VTS_01_0.BUP 06/20/2008 02:50 PM 147,456 VTS_01_0.IFO 06/20/2008 02:50 PM 87,863,296 VTS_01_0.VOB 06/20/2008 02:53 PM 1,073,739,776 VTS_01_1.VOB 06/20/2008 02:57 PM 1,073,739,776 VTS_01_2.VOB 06/20/2008 02:59 PM 1,073,739,776 VTS_01_3.VOB 06/20/2008 03:00 PM 903,088,128 VTS_01_4.VOB 06/20/2008 03:02 PM 1,073,739,776 VTS_01_5.VOB 06/20/2008 03:04 PM 1,073,739,776 VTS_01_6.VOB 06/20/2008 03:06 PM 1,073,739,776 VTS_01_7.VOB 06/20/2008 03:08 PM 784,902,144 VTS_01_8.VOB 13 File(s) 8,218,607,616 bytes 2 Dir(s) 40,520,073,216 bytes free C:\SM ALL VILLE_SEASON_1_DISC_1\VIDEO_TS> |
| ChrissyBoy posted 2008 Jun 26 03:55 |
| Hi,
I think you may have to reinstall the program but use a different folder rather than c:\Program Files (x86). Due to Vista the application can't write in that folder and so the Log file can't be created. C. |
| shnelson posted 2008 Jul 24 17:31 |
| I am getting the same error. Anything under 1gig is ok but large vob files will not convert
******************************************************************** ************************ SYSTEM INFORMATION ************************ ******************************************************************** ***************************** VOB2MPG ***************************** Name: VOB2MPG Title: Version: 2.5.0.0 Executable: C:\Program Files\BadgerIT\VOB2MPG\VOB2MPG.exe Executable size: 460 KB Executable size in bytes: 471040 Executable CreationTime: 1/1/2000 12:00:00 AM Executable LastWriteTime: 1/1/2000 12:00:00 AM Executable LastAccessTime: 1/1/2000 12:00:00 AM ****************************** Drives ******************************* **********************UNABLE TO GET SYSTEM INFO******************* ********************** Input Folder ******************* 15:26:18: Volume in drive C has no label. 15:26:18: Not enough storage is available to process this command. 15:26:18: Directory of C:\Users\Shaun\Test_Videos\The_Smiths 15:26:18: 07/24/2008 09:07 AM <DIR> . 15:26:18: 07/24/2008 09:07 AM <DIR> .. 15:26:18: 07/22/2008 07:46 PM 6,144 VIDEO_TS.BUP 15:26:18: 07/22/2008 07:46 PM 6,144 VIDEO_TS.IFO 15:26:18: 07/22/2008 07:46 PM 36,864 VTS_01_0.BUP 15:26:18: 07/22/2008 07:46 PM 36,864 VTS_01_0.IFO 15:26:18: 07/22/2008 07:46 PM 3,375,077,376 VTS_01_1.VOB 15:26:18: 5 File(s) 3,375,163,392 bytes 15:26:18: 2 Dir(s) 209,741,529,088 bytes free 15:26:18: C:\Users\Shaun\Test_Videos\The_Smiths> ********************** AV Details ******************* file=C:\Users\Shaun\Test_Videos\The_Smiths\VTS_01_1.VOB FormatName=mpeg Num_Frames=84628 DurationInSecs=2823 Duration=00:47:03.7 VideoCodec=mpeg2video VideoFFSTNum=0 Width=720 Height=480 Standard=NTSC BitRate=9561 AudioStreamCount=1 Audio1FFSTNum=1 Audio1StreamID=[0xa0] Audio1SampleRate=48000 Audio1Codec=pcm_s16be Audio1BitRate=192 Audio1Channels=2 ************************ END ************************ 15:26:19: FFmpeg version HEAD, Copyright (c) 2000-2004 Fabrice Bellard 15:26:19: configuration: --enable-a52 --enable-gpl --enable-memalign-hack --disable-debug --enable-pthreads 15:26:19: libavutil version: 49.0.0 15:26:19: libavcodec version: 51.9.0 15:26:19: libavformat version: 50.4.0 15:26:19: built on Jun 20 2006 11:22:30, gcc: 3.4.4 (mingw special) 15:26:19: Input #0, mpeg, from 'multi:C:\Users\Shaun\Test_Videos\The_Smiths\VTS_01_1.VOB*': 15:26:19: Duration: N/A, bitrate: N/A 15:26:19: Stream #0.0[0x1e0], 29.97 fps(r): Video: mpeg2video, yuv420p, 720x480, 9801 kb/s 15:26:19: Stream #0.1[0xa0]: Audio: pcm_s16be, 48000 Hz, stereo, 1536 kb/s 15:26:19: Assuming NTSC for target. 15:26:19: Output #0, dvd, to 'C:\Users\Shaun\Desktop\VTS_01.mpg': 15:26:19: Stream #0.0, 29.97 fps(c): Video: mpeg2video, yuv420p, 720x480, q=2-31, 9801 kb/s 15:26:19: Stream #0.1: Audio: pcm_s16be, 48000 Hz, stereo, 1536 kb/s 15:26:19: Stream mapping: 15:26:19: Stream #0.0 -> #0.0 15:26:19: Stream #0.1 -> #0.1 15:26:19: frame= 0 q=-1.0 Lsize= 0kB time=10000000000.0 bitrate= 0.0kbits/s 15:26:19: video:0kB audio:0kB global headers:0kB muxing overhead -1.#IND00% ********************** Output Folder ******************* 15:26:19: Volume in drive C has no label. 15:26:19: Not enough storage is available to process this command. 15:26:19: Directory of C:\Users\Shaun\Desktop 15:26:19: 07/24/2008 03:26 PM <DIR> . 15:26:19: 07/24/2008 03:26 PM <DIR> .. 15:26:19: 07/22/2008 03:08 PM 839 Any Video Converter.lnk 15:26:19: 04/24/2008 08:42 PM 794 DVD Shrink 3.2.lnk 15:26:19: 06/27/2008 08:24 AM 742 DVDFab 5.lnk 15:26:19: 07/23/2008 03:55 PM 818 Handbrake.lnk 15:26:19: 04/30/2008 07:33 PM 484 Invoices.lnk 15:26:19: 07/20/2008 07:25 PM 1,704 LimeWire 4.18.3.lnk 15:26:19: 07/24/2008 02:56 PM 2,165 TVersity.lnk 15:26:19: 07/24/2008 03:26 PM 0 VTS_01.mpg 15:26:19: 04/21/2008 07:57 PM 905 Yodm3D - Shortcut.lnk 15:26:19: 9 File(s) 8,451 bytes 15:26:19: 2 Dir(s) 209,742,512,128 bytes free 15:26:19: C:\Users\Shaun\Desktop> |
Login/Register to our forum to be able to post here.
