Forum archive - Vista problem with SVC2DVD
http://www.supermediastore.com/
Forum Archive Home -> SVCD2DVD & VOB2MPG -> Vista problem with SVC2DVD
PerryM posted 2009 Aug 26 16:19
I want to be able to turn HD TS files to (SD) DVD to send to a relative.
I tried the free HDTV2DVD but although it appears to run (i.e. no errors) it only encodes the sudio. I then tried the demo of SVCD2DVD and this worked fine (within its limitations). I thus splashed out on the full version (2.5) and it throws up several error messages including this one:
Version: SVCD2DVD 2.5
Build: 2.5.5030.0
Type: System.AccessViolationException
Source: SVCD2DVD
Message: Attempted to read or write protected memory. This is often an indication that other memory is corrupt.
InnerException:
StackTrace: at x3284ccece41ee22b.xd3764d4f1e921081.AuthorDVD(xc76139390a97debb xd2637df501625a82, x81974c36d7fdf1e1 xb4ee5c1758e9e983, Int32 xdc4f66b5011a3c9d, String[] x738d70b20493db82, Boolean x6b20cb17e8070d92, Boolean x3c21da9f928aac10)
at x3284ccece41ee22b.xd3764d4f1e921081.x2e6504f39decc498()
at x3284ccece41ee22b.xd3764d4f1e921081.xf81783e1b359ffc3()
at System.Threading.ThreadHelper.ThreadStart_Context(Object state)
at System.Threading.ExecutionContext.Run(ExecutionContext executionContext, ContextCallback callback, Object state)
at System.Threading.ThreadHelper.ThreadStart()
Any suggestions as to the problem gratefully received.
Ai Haibara posted 2009 Aug 26 19:26
You might have better luck getting an answer in the SVCD2DVD forum, here on VideoHelp, which the author (ChrissyBoy) frequents, though that's not the only area of VideoHelp he visits. :) Still, if you would like a moderator to move this post to that forum, just click on the Report This Post link at the bottom of your post, and mention it.
Have you tried running the program as an Administrator? Or in XP compatibility mode?
redwudz posted 2009 Aug 26 19:49
Moving you to the SVCD2DVD & VOB2MPG Forum.
And welcome to our forums. :)
Jikchung posted 2009 Aug 26 20:27
Are you running SVCD2DVD as administrator? Did you install to directory other than 'Program Files'?
http://forum.videohelp.com/topic324278.html#1776530
PerryM posted 2009 Aug 27 04:38
OK - read some suggestions and re-installed with folder directly in C drive (not in Program Files). Running as Administrator but still no joy - same error messages. Also will no longer play assets which DID work before (get continual rotating icon with lots of disc activity, and program appears to lock up).
ChrissyBoy posted 2009 Aug 27 04:57
PerryM :
Build: 2.5.5030.0
Source: SVCD2DVD
InnerException:
Can attach your log for this run please? (find logs via the help menu)
PerryM posted 2009 Aug 27 05:49
How about this one
svcd2dvdlog-20090827103736.txt
ChrissyBoy posted 2009 Aug 27 05:53
Looks like a problem with the 2 pass.... can you try without that option please?
PerryM posted 2009 Aug 27 06:15
OK - seems to be progressing this time with one pass encode set - I have to go out but I'll tell you the final result in an hour or so.
That leaves the problem of why the asset play won't work? I went back to HDTV2DVD and it now doesn't work on that either. Could it be a problem with FFDSHOW?
PerryM posted 2009 Aug 27 10:16
It finished making a DVD from a single 30min HD movie (H264 TS) in just over 2 hours (not inc burning). Trouble is it has produced a VideoTS of 3.4GB which is way over max bit rate! Still at least it is running now, so I'll try tweaking a few things.
PerryM posted 2009 Aug 27 13:34
I did another with the 'Safe Max Bitrate' button pressed but it still comes out over 3GB for the VideoTS which is over the max DVD rate even for an average! It is curious since the bar graph in the SVC2DVD main panel shows under 2GB which would be OK. FWIW I've attached the log for this last session.
svcd2dvdlog-20090827161911.txt
Login/Register to our forum to be able to post here.
Slysofts AnyDVD HD removes DVD and Blu-ray encryption and region coding. More info or download trial!
About   Advertise   Forum Archive   RSS Feeds   Statistics
