Forum Archive Home -> Video Conversion -> Video won't fit on dvd
Video won't fit on dvd | ||
| chevyfever posted 2009 Nov 06 06:24 | ||
| I downloaded Transformers Revenge of the Fallen in spanish it is 949MB long.When I convert it to
NTSC with Any Video Converter to burn with Nero 9 it is 5.43GB and it won't fit on a regular dvd.Is there a way to set ADC to convert to less GBs?Before it would convert to less but now it goes way up. | ||
| freebird73717 posted 2009 Nov 06 06:32 | ||
| Solve your problem easier by buying the dvd. | ||
| guns1inger posted 2009 Nov 06 06:40 | ||
| It is part of the new anti-piracy programme. No downloaded video will fit on a DVD any more.
Harsh, but true. Actually, it's all a lie. However if you are not smart enough to read the rules before posting then you won't be smart enough to solve your problem either, which is just as effective. | ||
| chevyfever posted 2009 Nov 06 07:41 | ||
| I have downloaded dozens of movies and they all fit.And thanks for the stupidity. | ||
| Noahtuck posted 2009 Nov 06 07:48 | ||
Speaking of "STUPID", what does it say right above the box you wrote your original post in ?? # Do NOT give, link, ask, or advocate WAREZ. # Warez includes downloaded copyrighted movies and TV-series/shows and copying rented movies. I guess you're not to bright either :?: :freak: | ||
| Baldrick posted 2009 Nov 06 07:50 | ||
| Buy them. |
Login/Register to our forum to be able to post here.
