VideoHelp.com forum archive
Your Ad Here
Forum Archive Home -> Software Playing -> Video codec problem?
thai1 posted 2008 Aug 30 02:38
Hi guys,
I have 2 XP systems with one happily producing error-free passes of FAVC.
The other produces many small frame errors in the second pass and can fail completely if I use both CPU cores. I suspect DiVX as the good system doesn't use it.
On checking the codecs I saw that the good one is using lvcodec2.dll, while the problem one is using i420vfw.dll, as well as having additionally mpg4c32.dll, ACDV.dll and DivX.dll. All other codecs are the same.
I changed the registry entry for VIDC.I420 from i420vfw.dll to lvcodec2.dll so as to be the same.
If I uninstal the DivX package I get the missing codec error.....
I don't understand how the good system works without DivX installed!
Any ideas as to what the good sytem is using - I am missing something here! :roll:
guns1inger posted 2008 Aug 30 02:43
Xvid or FFDShow will decode Divx. I suspect you have FFDShow on the PC that is encoding happily.
thai1 posted 2008 Aug 30 05:54
Thanks,
I noticed that I had downloaded FFDShow at the same time as DiVX on the problem PC, but was not installed.
Just tested with FFDShow installed and all is OK.
:D
Login/Register to our forum to be able to post here.
About   Advertise   Forum Archive   RSS Feeds   Statistics
