Forum archive - VHS tapes, Hauppauge capture cards, interlacing, and Sony Vegas Pro 9
http://www.supermediastore.com/
Forum Archive Home -> Restoration -> VHS tapes, Hauppauge capture cards, interlacing, and Sony Vegas Pro 9
othersteve posted 2009 Sep 10 07:03
Hey guys,
As much as I feel like I should know about video, I must just really suck at this stuff. I am trying to transfer some old VHS tapes of basketball games to DVD for a friend/customer, and I've pretty much got the process licked... except for the tricky interlacing issue. Here's what I'm doing (and I realize this probably is not ideal to begin with):
1) VCR via RCA -> S-Video adapter to S-Video In on back of Hauppauge HVR-1600.
2) WinTV 7 set to record from S-Video input to .ts files. (Heh, I couldn't get Vegas capture to work with the card.)
3) .ts files imported into Vegas, set to Upper Field First (I actually chose "match media"); no deinterlacing selected.
4) Sent through a Neat Video filter plug-in and then rendered out to MPEG-2 DVD format (480i), lower field first interlacing of course.
Problem is, the video is jumpy and goofy-looking, and you can definitely see signs of interlacing throughout. What in the world am I doing wrong?
Thanks very much in advance.
Steve
jagabo posted 2009 Sep 10 07:16
If your source is upper field first why are you encoding lower field first?
othersteve posted 2009 Sep 10 07:17
I thought DVD video required lower field first format in order to be fully compliant?
(Feel free at any point to inform me that I've no idea what I'm talking about) ;)
2Bdecided posted 2009 Sep 10 07:22
No, either is 100% fully compliant and fully supported (and FWIW TFF is more common).
It's DV that's BFF only.
Cheers,
David.
othersteve posted 2009 Sep 10 07:24
I love this place already.
OK, so I've tried going TFF -> TFF... here are the results I am coming up with:
http://www.slickboards.net/media/daleyadon-syracuse-uk-1-test.mpg
Does this look normal to you guys, or is something still amiss?
Thank you again, immensely!
Steve
jagabo posted 2009 Sep 10 07:31
You resized the video vertically at some point and this has caused cross contamination of the two fields. My guess is you removed the head switching noise at the bottom of the frame. Mask the noise with a black bar rather than cropping and resizing.
othersteve posted 2009 Sep 10 07:35
You guys are absolutely amazing. Now the video looks fantastic.
I owe you one!
Steve
Login/Register to our forum to be able to post here.
DVDFab DVD to DVD lets you backup DVDs to DVDr, AVI or MP4 for portable devices. More info or download trial!
About   Advertise   Forum Archive   RSS Feeds   Statistics
