Forum Archive Home -> Media Center PC / HTPC -> VGA to HDMI??
| VGA to HDMI?? | ||||
| BReeve posted 2008 Oct 01 13:18 | ||||
| I have a monitor that has a VGA port, however, it also has a HDMI port. Is it possible to have a way that the VGA lead somehow gets changed into HDMI? The reason being that the output of my arcade machine is 4:3 and it wont auto adjust and stretch the image to widescreen.
thanks, Barry | ||||
| nic2k4 posted 2008 Oct 01 13:58 | ||||
| Does your arcade machine have an HDMI output? VGA is an analog signal and HDMI is a digital one, the two don't mix. DVI has pins to carry the analog signal, that's why you can use a DVI to VGA adapter with it. | ||||
| redwudz posted 2008 Oct 01 14:10 | ||||
| Not all DVI connectors have analog available. http://en.wikipedia.org/wiki/Digital_Visual_Interface You can get cables that will output the VGA signal from the correct type of DVI connector, or you can get a DVI to HDMI cable if your box has a DVI output. The formats you will have available depend on the box and the displays settings. | ||||
| edDV posted 2008 Oct 01 14:36 | ||||
What is the arcade game and what output connections are available? What are the output settings available in the menus? | ||||
| BReeve posted 2008 Oct 01 15:04 | ||||
| its a jamma board with 1000 games on it.its basically a pc but it boots into the arcade program.its got a normal motherboard with vga, usb, sound output etc.
so you think a vga to dvi will display the picture stretched? | ||||
| edDV posted 2008 Oct 01 15:30 | ||||
Such monitors usually accept only DVI-D on the HDMI port. Your game only outputs analog VGA. If your monitor won't manual H-Size adjust for a 4:3 VGA input (which I doubt), you are out of luck. If you want something that will auto adjust aspect ratio, then you need to replace the monitor with an LCD-TV but test the TV before you buy. | ||||
| Timmychuck posted 2008 Oct 01 16:23 | ||||
| You can try this,but little expensive
http://www.tigerdirect.com/applications/SearchTools/item-details. ... ;CatId=467 |
Login/Register to our forum to be able to post here.
