Forum archive - VCDEasy Features
http://www.supermediastore.com/
Forum Archive Home -> VCDEasy General -> VCDEasy Features
VCDEasy Features
src2206 posted 2006 Jun 27 23:00
Hi,
I have two questions regarding VCDEasy:
1. Does it support CD to CD copy?
2. Does it have a Data Verification feature?
Thank you
Cornucopia posted 2006 Jun 29 17:05
Hi,
1. No
2. No
VCDEasy is a VCD authoring app with disc burning capability, not a disc burning app.
src2206 posted 2006 Jul 01 13:46
Thanks for replying :)
src2206 posted 2006 Jul 27 00:55
Well 1 more thing- can I choose the write/burn speed in VCD Easy? If yes then how ?
Please help a bit more!
Thank you
Cornucopia posted 2006 Jul 27 09:47
Yes,
[File | Settings | CDWriter] shows the burn settings.
This section/tool is, of course, just a GUI for CDRDAO, but it works quite well.
*Hint: If it doesn't want to work, changing the protocol to mmc-raw-forced usually takes care of problems (but don't do that unless you have to).
src2206 posted 2006 Jul 27 11:29
Thanks Scott
You're just great :)
Yeah I found it out and did not have to change the protocol too.
Thanks again
Login/Register to our forum to be able to post here.
VSO Software ConvertXtoDVD lets you convert any video like AVI,MKV to DVD easily. More info or download trial!
About   Advertise   Forum Archive   RSS Feeds   Statistics
