Forum Archive Home -> Audio -> URGENT! audioproblems with HV30
URGENT! audioproblems with HV30 |
| perik posted 2009 Oct 14 17:33 |
| Hello
I have plugged in an external mic on my HV30 but I still get the sound from the internal cameramic. Im using a preamp in between, the juicedlinkas an external preamp. how do I disconnect the internal cameramic and just get the sound from the external? thanks for the quick reply. Im going to get up early tomorrow and shoot and start to feel a little panic thanks Per |
| minidv2dvd posted 2009 Oct 14 17:55 |
| something wrong with your mic/amp. all that you need to do to use it is plug it in to the hv30. no power? bad pre-amp? |
| perik posted 2009 Oct 14 18:19 |
| works now. cause the internal mic shall be turned off automatically when I stick something into the external mic jack right?.
seems to work now though. phuu :) any recommended volumesettings on the hv30 for use with external mic? |
Login/Register to our forum to be able to post here.
