Forum archive - .ts to mkv conversion problem
http://www.supermediastore.com/
Forum Archive Home -> Blu-ray Ripping -> .ts to mkv conversion problem
txl posted 2009 Sep 15 05:11
Hello all,
I have a ripped movie in HD-DVD format that a friend gave me, I would like to convert it into MKV abnd i have problems with the sound.
I can convert it into mkv using super and stream settings all around (audio and video) but it loses the DTS audio track and I'd like to keep this one since it should be better than the AC3, how can I do this ?
Here are the file details
Vidéo
ID de menu : 1 (0x1)
Format : MPEG Video
Version du format : Version 2
Profil du format : Main@High
Paramètres du format, Matrice : Par défaut
Durée : 29mn 17s
Type de débit : Variable
Débit nominal : 40,0 Mb/s
Largeur : 1 920 pixels
Hauteur : 1 080 pixels
Format à l'écran : 16/9
Images par seconde : 23,976 Im/s
Colorimétrie : 4:2:0
Type d'image : Progressif
Bits/(Pixel*Image) : 0.805
Audio #1
Format : DTS
Format/Info : Digital Theater Systems
Profil du format : MA
Durée : 29mn 17s
Canaux : 6 canaux
Position des cannaux : Front: L C R, Surround: L R, LFE
Echantillonnage : 48,0 KHz
Résolution : 24 bits
Langue : Anglais
Audio #2
Format : AC-3
Format/Info : Audio Coding 3
Durée : 29mn 16s
Type de débit : Constant
Débit : 448 Kbps
Canaux : 6 canaux
Taille du flux : 93,8 Mio (2%)
Langue : Anglais
Baldrick posted 2009 Sep 15 05:19
You can use tsmuxer to rip out the dts from the ts and then add it to the mkv using using mkvtoolnix.
And I would use Ripbot264 to convert the ts to mkv h264. It can also keep the dts and ac3 audio.
Login/Register to our forum to be able to post here.
DVDFab DVD to DVD lets you backup DVDs to DVDr, AVI or MP4 for portable devices. More info or download trial!
About   Advertise   Forum Archive   RSS Feeds   Statistics
