Forum Archive Home -> Blu-ray to AVI/MP4/MKV/WMV -> Trouble with AVI files
| Trouble with AVI files |
| Warhammer posted 2008 Sep 24 12:32 |
| I am having trouble opening a AVI file created on a mac to play on windows XP . I have tried all forms of software but it does not work ???
Needed for a project due tommorow. |
| poisondeathray posted 2008 Sep 24 12:49 |
| Use mediainfo or gspot to determine what video & audio codecs are required. Install the required codecs.
You can also try playing back VLC, Mplayer or KMPlayer which all have internal codecs and are not reliant on system installed codecs. |
| redwudz posted 2008 Sep 24 13:49 |
| Tried the freeware Quicktime Alternative player? I suspect that format if it's from a Mac. Gspot or MediaInfo may tell you. It may have a .mov extension. You can also try VLC, but QT is proprietary, so VLC may not play it either.
And welcome to our forums. :) |
| filmboss80 posted 2008 Sep 24 14:25 |
| What form of AVI file is it? Uncompressed? DV? Divx? They are all very different. If it is a DV-AVI, I have recently learned that Macs use Raw DV, while Windows-based editors use either Type-1 or Type-2 DV (mostly the latter.)
Load the AVI on your XP computer. Download GSpot (see Tools on this site) and analyze the file to determine the type of AVI you have. |
Login/Register to our forum to be able to post here.
