VideoHelp.com forum archive
http://www.supermediastore.com/
Forum Archive Home -> Feedback -> tool auto-linking messing with smileys
Supreme2k posted 2008 Jun 08 14:04
I don't know if this is the only one, but here's an example:
http://forum.videohelp.com/topic352007.html#1855255
It seems that one of the tools has the same name as a smiley, so it overrides the smiley tag. Not sure if you can fix one without messing up the other, though.
redwudz posted 2008 Jul 01 19:13
The 'wink' Emoticon does that because there is a program in tools called 'wink'. If you 'Disable automatic tool link' like this, it should work for that post. This has been a problem for a while. :wink: :wink: :wink: :wink:
Maybe Baldrick can rename the wink Emoticon when he has some spare time. :wink: :)
Baldrick posted 2008 Jul 02 03:30
:wink:
wink 2
edit: fixed....you have to type wink 2 for the wink tool. :).
Login/Register to our forum to be able to post here.
About   Advertise   Forum Archive   RSS Feeds   Statistics
