Forum Archive Home -> Video Conversion -> TMPGENC 4.0 Xpress Weird Problem! (Shows Green Bar On Left Side Of Video)
TMPGENC 4.0 Xpress Weird Problem! (Shows Green Bar On Left Side Of Video) | ||||
| hypnoticpimp posted 2009 Apr 14 20:08 | ||||
| I have this mp4 video and when i load it up on tmpgenc 4.0 xpress is shows this annoying green line on the left side of the side.
even when i export it it still shows that green line on the left side. anyone know how to fix this issue? http://i42.tinypic.com/33jsjz6.jpg | ||||
| jagabo posted 2009 Apr 14 20:11 | ||||
| The green bar is probably part of the video. Mask it out. | ||||
| hypnoticpimp posted 2009 Apr 15 00:16 | ||||
| no its not part of the video. cause when i play in VLC media player. the original video it doesnt show the green bar. but when i try to edit the video with tmpgenc. when i load it . it shows that green bar | ||||
| jagabo posted 2009 Apr 15 09:05 | ||||
| I just noticed that the frame dimensions reported at the bottom of your image is 740x480. In general video should be mod16, not mod4. Crop it down to 720x480 if you're making a DVD. Or 736x480 if you're making something that doesn't require 720. | ||||
| hypnoticpimp posted 2009 Oct 27 02:45 | ||||
| Having problems converting this mov video on tmpgenc
ok look at the screenshot
if you notice it says 720 x 480 thats the orginal video size. I dont know how to mask like you say Also when i convert the video . the video doesnt fill up the player it shows alot of black borders heres a screenshot of what i mean
its suppose to fill up the player nicely like this
what can i do to fix this so that green bar goes away and the video fills up player when its converted on TMPPGENC please give me exact instructions. Cause i dont know how to mask on TMPGENC | ||||
| jagabo posted 2009 Oct 27 05:54 | ||||
| I don't have the newer TEMGEnc tools but in the older TMPGEnc Plus you would do this:
First tell TMPGEnc you source aspect ratio is 16:9 Display or 16:9 525 line NTSC. Make sure Video Arrange Method is set to Full Screen. Then tell it you want 16:9 Display output. To mask the green bar go to Clip Frame (looks like it's Picture Crop in your version) and use the tool to remove the green bar. Elect to Mask instead of Crop: ![]() | ||||
| hypnoticpimp posted 2009 Oct 29 08:54 | ||||
| ok but how about the problem with video not filling up player after it gets converted | ||||
| jagabo posted 2009 Oct 29 09:27 | ||||
| hypnoticpimp posted 2009 Nov 01 20:23 | ||||
| could u tell me where the Video Arrange Method option is located on tmpgenc | ||||
| jagabo posted 2009 Nov 01 21:33 | ||||
Like I said, I only have an old version of TMPGEnc Plus but this may help you:
Login/Register to our forum to be able to post here.
