Forum Archive Home -> SVCD2DVD General -> System.UnauthorizedAccessException error after WinXP SP3 install
| System.UnauthorizedAccessException error after WinXP SP3 install | ||||
| scoop46 posted 2008 Aug 21 15:10 | ||||
| I've never had a problem with SVC2DVD v2 until a few days ago. I had just updated WinXP to SP3, when I received the following:
Version: SVCD2DVD 2.1 Build: 2.1.2278.16886 Type: System.UnauthorizedAccessException Source: mscorlib Message: Access to the path "G:\My Videos\Star Trek-(Episode 61 - Spectre of the Gun)_S2D.mpg" is denied. InnerException: StackTrace: at System.IO.__Error.WinIOError(Int32 errorCode, String str) at System.IO.File.Delete(String path) at x3284ccece41ee22b.xd3764d4f1e921081.x2e6504f39decc498() at x3284ccece41ee22b.xd3764d4f1e921081.xf81783e1b359ffc3() This upgrade has also affected other video related programs such as BeyondTV. Is there some explanation/fix for the newfound errors? Thanks, Mike | ||||
| ChrissyBoy posted 2008 Aug 29 17:23 | ||||
| The latest version should be ok with SP3... | ||||
| scoop46 posted 2008 Sep 18 13:08 | ||||
Type: System.UnauthorizedAccessException Source: mscorlib Message: Access to the path "G:\My Videos\Star Trek-(Episode 61 - Spectre of the Gun)_S2D.mpg" is denied. If I sit there and babysit it while it's running and change it from read only, it works fine, but it's a pain in the backside to have to do that. How can I prevent the _S2D file from being made "read-only"? Mike | ||||
| scoop46 posted 2008 Oct 19 14:34 | ||||
| Does anyone out there know of an alternative to SVCD2DVD? I want a package that is SUPPORTED with respect to technical issues. Thanks in advance. | ||||
| Jikchung posted 2008 Oct 19 15:42 | ||||
| This product IS supprted, your problem is not with SVCD2DVD, but with the Windows update. I have been having the same error off and on with files being made read only. I also have a Vista PC that it is happening on as well and it's not exclusive to S2D files. Be sure you know where your problem lies before assessing blame. | ||||
| scoop46 posted 2008 Oct 19 15:59 | ||||
| Look Dwight! I am simply a user, not a software developer. In the time since my original post (and follow up) I have received 2 replies. Both say "it's not our problem" but not offering any suggestions. Can those who know how the program is supposed to perform suggest a solution...or just shrug and hope I'll go away? I usually go with freeware where I don't expect any help. I bought this package and get the same level of support. That's Not good business and I complain and assign blame to whomever I want until some responsible person steps up with some useful input. Are YOY that responsible person? If you're not that person, then shut up and ignore my post like the other 360 viewers of it have done. I asked for an alternative to this package...not a lecture from you. | ||||
| aedipuss posted 2008 Oct 19 16:44 | ||||
| scoop - you were given an answer by the author of the program. did you do as you were told? update to the latest version? | ||||
| Jikchung posted 2008 Oct 19 17:02 | ||||
| scoop46-
Just because one is a software developer doesn't mean that they are to help with the ins and outs of ALL your problems. CB did not write windows or the service pack you applied, which is what started your problems.
Upgrading to the latest release did fix your problem as CB suggested it would, you now have another problem occuring that is not S2D related and are expecting CB to fix it also - how is he to do that when the error is not with his program? As I said, I have this problem from time to time as well and have not found the fix as yet - it really isn't a widespread issue. It also isn't an issue with S2D.
This kind of attitude will get you nowhere for two reasons: 1. I offered you help from my experience and to try and direct you to something that might help - your response is to tell me to shut up. With such a flowery nature about you, who do you think will help you further? 2. Assigning blame willy-nilly is just stupid and will also get you nowhere, and will lead to you being further ignored. The problem is not inherent to S2D, so why not post in a more appropriate forum for your Windows Update induced error? | ||||
| k_vic posted 2008 Oct 19 19:13 | ||||
| Mike -
Just curious - do you have Windows XP Media Center Edition? SP3 does not have a real good track record running on Windows XP MCE - I cannot get it to install properly on my Win XP MCE computer - even after wiping the hard drive clean and installing everything from scratch. I am still using SP2 on my WinXP MCE computer. SP3 installs and runs great on my Win XP Home and my Win XP Pro computers. My suggestion - especially if you are having so many issues with SP3 - is to uninstall it. It is not a required update, it adds no new functionality to Windows XP, and not having it installed does not prohibit you from getting other security updates from Microsoft. If life was good prior to SP3, go back to SP2. Good luck! | ||||
| mr nice posted 2008 Oct 20 05:23 | ||||
| Ok, it could be one of two thing's 1) It could be security error were an operating system denies access because of an I/O. 2) Or it could be a NET problem, do you have 2008 Net Framework 3.5 or 2005 Net Framework 2.0 if not then you will need them both. I dont use Vista there is still to many bug's in the softeware I'll stick with Xp for now. Hope this help's if it does I want £20. lol :D | ||||
| scoop46 posted 2008 Oct 20 09:03 | ||||
| Thanks to all who responded (seriously, all of you). Yesterday I finally just removed SP3 and for now everything is back to normal. I think I need to scrub my hard drive and reinstall my OS. I'll readdress the SP3 issue when I have a more stable platform. Thanks again. |
Login/Register to our forum to be able to post here.
