Forum Archive Home -> Portable Video -> supportPlus 20GB or sorell SV-10 , problems with the video recorder featur
supportPlus 20GB or sorell SV-10 , problems with the video recorder featur | ||
| ari dubov posted 2007 May 08 22:18 | ||
| I own a supportPlus 20GB which is the same thing as sorell SV-10 PMP, and it works fine, except the video camera feature, whenever I try to record a video, and error pops up stateing a "file can not be created" it used to work fine before and I was able to video record short movies. I tried to reset I tried to replace the movie record file in the directory, but none worked. I also could not find any support on this issue please help.
Ari Dubov | ||
| UncleChuckle posted 2007 May 18 01:25 | ||
| You're not alone. Mine had been working fine. I went to use it tonight... "File Creating Error" pops up. Hooked it up, checked the directory was there, deleted it, replaced it. You name it... Same crap. MP3 recording does the same thing. (Only that also crashes the player).
Really not sure what to do now. This is bloody depressing as I've only had it two months:( Did you ever figure out how to fix it? | ||
| UncleChuckle posted 2007 May 18 03:36 | ||
| Doing some digging, and finding some very odd Korean information that when translated mentioned blood and summer solstices (seriously) the solution seems to be back up the contents and format the drive. Did that, problem solved.
Bet it's related to me removing it without doing the "safe removal" thing. | ||
| ari dubov posted 2007 May 21 15:56 | ||
no still not working, hopefully someone can help | ||
| ScottoGato posted 2007 Oct 30 16:14 | ||
| Same thing just happened to me. I hardly use my record feature, but it comes in handy for when I do want to record.
I was using Sorrell's firmware of 2.26 or something or rather. That was due to me upgrading from the original SupportPlus firmware. I decided to go back to a SupportPlus firmware. It now works flawlessly once again. I found a SupportPlus firmware here: http://www.k3pgp.org/bikecam.htm At the very bottom, it gives some instructions on upgrading the firmware. There's a small mistake...you don't put the .bin file into the DATA folder, you put it into the SYSTEM folder. It will update, and your recorder should be functional again. SupportPlus players rock! | ||
| ScottoGato posted 2007 Oct 30 16:16 | ||
| http://www.k3pgp.org/Software/SP-PMP-51_sv-10_rom.zip
That's the direct link to the SupportPlus firmware file. Forgot to put there. You have to extract the .bin file and put it into the SYSTEM folder. Unplug your USB, and it should begin updating! BE SURE TO HAVE A FULL BATTERY CHARGE BEFORE DOING THIS! | ||
| ari dubov posted 2008 Mar 20 00:09 | ||
| thanks | ||
| ari dubov posted 2008 Mar 30 12:00 | ||
| it worked | ||
| hekticshane posted 2008 May 18 23:05 | ||
I have a sv-10 sorell pmp, on the screen it say`s, 'file system error'. how can i get to work the way it is suppose to? | ||
| sdtbftone1 posted 2009 Jul 16 07:01 | ||
| I have one also-but even after resetting it I turn the power of and it goes to an opening screen then shuts off-any suggestions |
Login/Register to our forum to be able to post here.
