Forum Archive Home -> Subtitle -> subtitles won't show!
subtitles won't show! |
| wawawa posted 2009 Nov 02 23:36 |
| Hello, so I tried using the subtitle creater wizard dvd authoring tool, and editing the ifo file, however with either when the process is done my subtitles won't show, I really don't know why, when I preview them everything seems ok.
On the other hand I tried total video converter to just do a mov, it works, the only problem being the subtitles come out black. the other problem I have is whatever I do in wubtitle workshop I cannot open in subttilte creator, don't know if all these are related. Thanks alot for any help, or recommendations. :( |
| Bjs posted 2009 Nov 09 03:16 |
| Welcome wawawa
Subtitle workshop > output type as subrip (srt) Subtitle creator > CTRL + O > select the new srt subtitle > Make adjustments > output type as sup If while authoring dvd it should close / error, relaunch wizard and hit start ... worked fine in vlc, nero showtime |
Login/Register to our forum to be able to post here.
