Forum Archive Home -> Video Streaming -> Streaming with TVersity and AC3 audio
Streaming with TVersity and AC3 audio | ||
| Igniss posted 2009 Oct 23 16:36 | ||
| Ive got this avi file the video is Xvid MPEG4 the audio is 5.1 AC3.
When i play it on my pc it plays fine without trouble, when i want to stream it it gives an error that it cant play, the issue has been narrowed down to the AC3 part. I used ffdshow but now i disabled AC3 in there and use AC3Filter instead but it still doesnt work. If i check the SPDIF(passthrough) in the settings it will work but it will go out of sync because the video is transcoded when synced. So i heard about this program graphedit, downloaded that, and it can play the streamed url with audio, yet wmp (on same pc) or ps3 cant play it. Any ideas? | ||
| Baldrick posted 2009 Oct 23 16:41 | ||
| Maybe try stream using the PS3 Media Server. Yep, it's named ps3 but it should work for the xbox360 too. | ||
| Igniss posted 2009 Oct 23 16:48 | ||
Hmz never tried that program however i been using tversity for a while now always been happy about it, dont feel like changing programs on every little hickup + im offcourse curious as too whats causing it ;) | ||
| Baldrick posted 2009 Oct 23 16:51 | ||
| I guess you have tried searched in http://forums.tversity.com/ ? And maybe ask there also. | ||
| Igniss posted 2009 Oct 23 16:52 | ||
| Yup also made a post there but the only replies i got so far where directed to problems with the sound itself not the soundcodec (like suggestions of changing khz etc etc)
EDIT: i must admit im not sure how graphedit handles the url cause if it first copies the entire file thats the reason why it loads in there, because if i open the url in wmp and let it copy the file it also plays fine its only the actual streaming that gives a problem |
Login/Register to our forum to be able to post here.
