Forum archive - Streaming TV Over a network!
http://www.supermediastore.com/
Forum Archive Home -> Video Streaming -> Streaming TV Over a network!
Brianmaiden posted 2009 Nov 13 09:05
I'm trying to stream Live TV over a netwotk to 4 or 5 PC's. I've seen the very useful guided on this site but i think i've bought the wrong card!
The card i purchased is a Kworld Plus TV PE355-2T Dual DVB-T PCI-Express card. but am having no luck with getting it to work with any of the suggested streaming software.
Could anyone recommend a card thats capable of doing the network streaming this got a budget upto £60.
Thanks in advance
Baldrick posted 2009 Nov 13 09:12
WHat tools have you tried? I would tyr VLC Media PLayer and JTVLAN. They should work with most dvb cards.
Brianmaiden posted 2009 Nov 13 09:30
Hi Baldrick
thanks for your quick reply!
I've followed your guide using the Windows media 9 encoder pack - the unreal media stream VLC and star media serverbut i've had no luck at all. The card isn't seen by any of the software. i know the card is installed properly as i've benn watching tv on it!
The card is capable of recording to Hard Drive using the software that came with it - Arcsoft TotalMedia.
Ive not tried JTVLAN software though.
The card only has a tv in and no TV out does this make any difference?
Brianmaiden posted 2009 Nov 16 05:23
I've tried the JTVLAN software and am still having no luck.
can you recommend a card that would do the job streaming with the windows media player 9 encoder??
thanks in advance
Bjs posted 2009 Nov 16 06:41
Here's something else > Streaming dvb
Ive already tried it with the Fission twin dvb-t (sold via aldi's in au) ... google search error = alt-dev_bda2driver.rar (follow the readme) and was up and running :)
Almost forgot the link I got that rar archive from > here ... tested with avast, clean / no password.
Incase some ask ... this archive is for ALTDVB
Brianmaiden posted 2009 Nov 16 09:58
hi BJ's thanksa for the link but i cant seem to find the version of the ALTDVB software the article is refering to (Version 2) the Altdvb website has been suspended :( so i cant get to download anything from there.
the 2.2 version didnt seem to have the network srv files that it refered too
Think i'll have to bite the bullet and get a new card - anyone recommend a Capture card that i can use to stream live TV to 4 or 5 PC's running XP?
Brianmaiden posted 2009 Nov 16 10:19
been recommended this:
hauppauge - WinTV HVR-1300 PCI DVB-T Receiver / Analogue TV Tuner / Video Input Adapter
do you thimk it will do the job??
Login/Register to our forum to be able to post here.
VSO Software ConvertXtoDVD lets you convert any video like AVI,MKV to DVD easily. More info or download trial!
About   Advertise   Forum   Forum Archive   RSS Feeds   Statistics   Tools
