Forum archive - Streaming MOV
http://www.supermediastore.com/
Forum Archive Home -> Video Streaming -> Streaming MOV
Streaming MOV
jfreak53 posted 2009 Oct 12 18:20
Ok I have converted an AVI to MOV using WinFF(FFMPEG) and according to longtail the JW Player and flash support MOV files. But still no go. It won't stream and it won't load. You can check this out here:
http://www.digitaleramarketing.net/video/joel/player-test.htm
It's the last player. Turn off the HD button then turn back on again to get the MOV file. I cannot get this to stream I've tried regular after convert then I figured it must be something with the ATOM again so I tried faststart and it won't stream. I thought Flash played MOV?
What am I doing wrong here? Any ideas?
Thanks in advance.
minidv2dvd posted 2009 Oct 12 18:56
not as far as i know. your choices are .flv or .mp4 - .mov is a different beast best left for quicktime player.
jfreak53 posted 2009 Oct 14 08:20
Ok thanks for your help. After playing a bit I find out that it will stream MOV file but only if it's encoded using h.264 instead of QT. So basically it turns itself into an MP4. And you also have to use faststart to move the ATOM. So basically it's an MP4, I reiterate.
So in conclusion, no Flash will not stream MOV files, it will stream the files if it is containing h.264.
Thanks again.
ricardouk posted 2009 Oct 14 11:07
You can just use Avanti to remux the mov file and resave it as an MP4, it wont reconvert the file, check with mediainfo before to see if the file was encoded with their h264 encoder
Login/Register to our forum to be able to post here.
Replay Video Capture, if you can Watch it, you can Capture it ! and save it to your computer. More info or download trial!
About   Advertise   Forum Archive   RSS Feeds   Statistics
