Forum Archive Home -> Audio -> Split an mp3 file
Split an mp3 file | ||||
| kschwi posted 2009 Nov 10 19:58 | ||||
| Hi,
I would like to convert some mp3 files (they are old radio broadcasts of baseball games in the public domain) to an audio CD-Rs to listen in my car CD player. I have been able to do this with my son's i-tunes and think I can do this with Img-Burn. However, some of these mp3 files are TOO big to fit onto a single CD-R as the CD-R will only hold 80 minutes. If I can split the mp3 file into 2 or three parts I can do this. What is the best freeware to split an mp3 file into parts without a loss in quality and how do I proceed? Thanks! | ||||
| t0nee1 posted 2009 Nov 10 20:46 | ||||
| MP3DirectCut | ||||
| kschwi posted 2009 Nov 11 07:28 | ||||
| Thanks. Is there a guide that explains how to do this? | ||||
| jman98 posted 2009 Nov 11 07:45 | ||||
| Audacity might also be useful and I think there are guides available on the internet on how to use it. | ||||
| Baldrick posted 2009 Nov 11 08:27 | ||||
| http://www.geocities.co.jp/SiliconValley-SanJose/2485/mp3DirectCu ... ml#cutting | ||||
| AlanHK posted 2009 Nov 11 08:54 | ||||
Click the ? on its toolbar to see the manual. See "Split into multiple files". | ||||
| dessieclive posted 2009 Nov 11 09:37 | ||||
| Shuangs Audio Editor | ||||
| MOVIEGEEK posted 2009 Nov 11 11:04 | ||||
| My favorite is Visual MP3 Splitter, it's fast and it maintains the ID3 tags. | ||||
| kschwi posted 2009 Nov 14 10:30 | ||||
| Maintaining the ID3 tags must have some importance but I am not sure what that means. What are ID3 tags?
Do the other programs do that as well? | ||||
| AlanHK posted 2009 Nov 14 10:41 | ||||
The info -- title, artist, genre -- that players show when you play an MP3. Mp3DirectCut can preserve ID3s if you set this -- Edit/tag ID3. I'd expect most MP3 editor can do that. | ||||
| kschwi posted 2009 Nov 14 11:01 | ||||
| Thanks,
My main objective is to split these so they can fit on a couple of CD-Rs in a format compatible with a CD player. In the audio format (if that is the correct term) it can only hold 80 minutes of a game. These mp3 files then are too big to convert to this format. I need to find a good stopping point in the game (probably at the end of an inning) before the 80 minute mark and then split them and convert them so they will be playable in an older car CD player. I'm guessing finding the right spot maybe the hardest part or maybe these programs allow you to listen to the mp3 to set where you want to split them. | ||||
| AlanHK posted 2009 Nov 14 12:48 | ||||
Yes, they all do. Just download MP3DirectCut and try it. It's free and quite small. My 12-year-old daughter has been using this for the last year to edit her music collection. It's easy once you get the hang of it, but do read the included help for how to select, cut and paste and save. You can mark a selection, and then play up to its end, and from the end on, before committing to a cut. | ||||
| Summersun78 posted 2009 Nov 14 17:52 | ||||
| Try Nero Wav Editor, in that prog u can make fade in and out as whell....
That what i use when i rip some radio, and it works fine... You do have to convert the wav file to mp3 again after u have edited it..... | ||||
| Ai Haibara posted 2009 Nov 14 17:58 | ||||
| Umm...
MP3DirectCut. You don't have to buy Nero, if you don't already have it; it's free, and you don't have to convert or re-encode the MP3 to cut it. (No quality loss, in other words.) Edit: If you're looking to add effects to an audio track, such as fade in/out, you can easily do that with Audacity, or any other sound editor (not just Nero's editor). Of course, since you're actually modifying the sound data itself, you WILL have to re-encode... | ||||
| AlanHK posted 2009 Nov 14 22:10 | ||||
Actually, MP3DirectCut can do that too. It changes the volume, globally or locally (as fades), losslessly without reencoding. | ||||
| Ai Haibara posted 2009 Nov 14 22:15 | ||||
| Oh, okay. :oops: I was attempting to make a blanket statement for effects in general, though, not just fading. :) | ||||
| kschwi posted 2009 Dec 07 09:27 | ||||
| I've been able to split the mp3 file with mp3direct cut. I've done 2 so far. I do have a couple more questions.
It might be the mp3 files I am working with(150-180 radio broadcasts)but it would be helpful if I could easily advance 20 minutes at time to find a break point. On the second row of buttons skipping a large step forward is only about 10-20 seconds. Go to next edit range takes me to the end of the file. Is there a way to put two cuts on the same file? Right now I set a cut point and then click file save split. It then creates two files. I do make these into 3 files so it might be a little easier to make 2 breaks in the mp3 file. When I am done it asks me to save my project, but not sure why this is needed as it already created a file when I said save split. Finally, with these old baseball audio games there is some background noise sometimes a little static or maybe a hum or a tinny sound. Any easy way to filter that out using this program (or maybe another) any still maintain the announcer and crowd noise? | ||||
| AlanHK posted 2009 Dec 07 09:39 | ||||
MP3DirectCut can only cut, paste and change volume. If you want to do that, then you need a full-blown audio editor. Audacity (latest 1.3.10) is free and pretty good. See http://wiki.audacityteam.org/index.php?title=Noise_Removal | ||||
| kschwi posted 2009 Dec 07 09:48 | ||||
| I did find the answer to my first question. there is a slide bar that can move the file as far into the program as I'd like.
I am getting an error message when I click save split this morning...Error could not create or write to file. It does create a file for the first third but does not split the rest into a separate file. I think this problem started after I changed the file name. | ||||
| kschwi posted 2009 Dec 11 12:25 | ||||
| Hi,
I still have 2 questions about mp3direct cut: When I am done it asks me to save my project, but not sure why this is needed as it already created a file when I said save split. Sometimes after I click File/Save Split I get a message stating: While saving 2 files 1re-sync occured. What does this mean? Do I need to do this over? Thanks in advance for your help. | ||||
| AlanHK posted 2009 Dec 11 23:27 | ||||
See the manual under "Project files".
If you're happy with your saved MP3, don't worry about saving a project file. I never bother myself. Since I usually delete the original MP3 they refer to the project file would be useless. But if you're doing a series of cuts and saves, it would let you easily stop and continue editing later. As for resync, see http://public.globalnet.hr/~jsinkovi/stranice/FAQ.htm
So just play the saved files and check if they're okay. I think it should be obvious if they're not. |
Login/Register to our forum to be able to post here.
