Forum Archive Home -> Media Center PC / HTPC -> Some Yes or No questions
| Some Yes or No questions | ||||||||
| the_importer posted 2008 Jun 28 18:22 | ||||||||
| Hi there,
I have some simple Yes or No questions to ask: 1- When connecting a PC to an LCD to via the VGA port (VGA to VGA) and playing a regular DVD movie, will the resolution be progressive (I'm using Media Player Classic)? 2- When connecting a PC to an LCD to via the VGA port (VGA to VGA) and playing a Blu-Ray movie, will the resolution be High resolution (would be using PowerDVD that comes with the LG drive)? Thank you | ||||||||
| Nelson37 posted 2008 Jun 28 18:46 | ||||||||
| 1. depends on the DVD and software settings.
2. NO. | ||||||||
| the_importer posted 2008 Jun 28 19:46 | ||||||||
OK, I'll try to fig some info on Media Player Classic. As for the 2nd question, would this mean that Digital is required for High Def? Meaning that neither VGA or Component cables can display Blu-Ray movies? | ||||||||
| yoda313 posted 2008 Jun 29 09:21 | ||||||||
| For bluray you must use hdmi for the hdcp protection issue. Your only other option is to rip it via anydvdhd. Though my understanding is there is no easy way to play ripped files without conversion. It seems if it is a BD+ title playback of the original files will be difficult.
You can get a simple 30.00 dvi-hdmi cable to hook up the pc that way assuming your set has an hdmi input. Your other option without ripping is to look for an hdcp stripper. I forgot the name but if you search the net for hdcp stripper you should fine something. I can't say anything about quality or other issues involved as I haven't used it. The one model I saw hooked up onto the vga port to remove any hdcp restrictions. How it works exactly is beyond me and I don't know if it has any glitches or stuttering. As far as the resolution of the playback over vga it will be whatever resolution you output from the computer and I believe any video from a pc is progressive. Though i don't know that for a fact. | ||||||||
| rallynavvie posted 2008 Jun 29 10:24 | ||||||||
| Actually any HDCP-capable connection will work so DVI-DVI will work as long as it's supported. I haven't heard of any HDCP hacks that work very well on the fly yet, but then I think putting a BRD drive in my PC is silly when I have a PS3 sitting next to it. | ||||||||
| yoda313 posted 2008 Jun 29 10:29 | ||||||||
| Yes but a brd drive will allow ripping :)
Actually what I'm interested in is the "digital copy" that is included with the RAMBO Bluray Disc. I posted a question on it here but nobody responded yet. If that was an official wmv or avi file that you can use on "authorized" devices like a ps3 or zune or 360 I'd like to know. I want more movies to use that. | ||||||||
| the_importer posted 2008 Jun 29 11:13 | ||||||||
So you're saying that component cables on a standard Blu-Ray player wouldn't work either then since a VGA cable doesn't (it's pretty much the same). | ||||||||
| yoda313 posted 2008 Jun 29 14:05 | ||||||||
| I'm not sure about component for bluray. I THINK they may be downressed to 720 or 480p. I can't say for sure. I only use hdmi for my ps3 so I haven't tested any restrictions on component for ps3. | ||||||||
| the_importer posted 2008 Jun 29 14:50 | ||||||||
Well I know that a High Def cable box can output to 1080i and 720pwith components, so I don't see why they wouldn't be able to do it on a Blu-Ray. | ||||||||
| jagabo posted 2008 Jun 29 15:11 | ||||||||
I think this is what yoda is talking about: http://www.engadget.com/2005/07/15/spatz-techs-dvimagic-killing-on-hdcp/ As far as I can tell this device is more myth than reality. It disappeared from Spatz's web site shortly after hitting the news. I've never seen any report from anybody who had one. | ||||||||
| Nelson37 posted 2008 Jun 29 17:02 | ||||||||
| While there is no hardware reason that component could not possibly work with Blue-ray, SFAIK the designers of the system specifically designed it to prevent this, unless you want low definition. No HDCP, no hi-def from Blu-Ray.
You can absolutely get interlaced playback from a PC, and some DVD are native interlaced. I have also seen the HDMI stripper product, also briefly, and neither have I heard of anyone, anywhere who has actually used one. | ||||||||
| Nelson37 posted 2008 Jun 29 17:05 | ||||||||
| Forgot to add this - the label on the box indicated the digital copy was specifically intended for other devices, pretty sure the Zune was mentioned. I don't own this, but after reading your post the box caught my eye. No other HD disks appeared to offer such a feature. | ||||||||
| jagabo posted 2008 Jun 29 17:29 | ||||||||
A low quality WMV no doubt. And the main BD feature wasn't digital? LOL | ||||||||
| the_importer posted 2008 Jun 29 18:47 | ||||||||
So are you saying that a Blu-Ray player like this one is not a real Blu-Ray player: http://tinyurl.com/3k3tfm | ||||||||
| jagabo posted 2008 Jun 29 18:53 | ||||||||
The BD/HDCP spec allows any disc to disable HD component output if it wants. And the HDCP spec requires that no device produced after 2011 allow HD component video. And no analog output at all is allowed after 2013. | ||||||||
| the_importer posted 2008 Jun 29 19:40 | ||||||||
So this Blu-Ray will be obsolete in a few year since it doesn't support HDCP. Also, if Hollywood is wrong and most of the consumers haven't purchased and HDTV with a Blu-Ray player by then, the movie industry is screwed :P The future of media industry should be interesting. | ||||||||
| jagabo posted 2008 Jun 29 21:05 | ||||||||
I find it hard to believe that player is not HDCP compliant. Sony would never give it a BD licence. | ||||||||
| Nelson37 posted 2008 Jun 29 21:16 | ||||||||
| Interesting it does not specifically list Blu-Ray under the compatibility list.
Wonder if the spec would allow for BD playback in lo-res, which is then up-converted just as it does for a standard DVD? Sort of a half-ass way around the licensing agreement? | ||||||||
| the_importer posted 2008 Jun 29 21:19 | ||||||||
Probably not a requirement yet then or this wouldn't be on the market. | ||||||||
| jagabo posted 2008 Jun 29 21:56 | ||||||||
| HDCP has been a requirement for Blu-ray HDMI connections since day one. That Futureshop add is simply wrong. Sony will not allow, under any circumstances, encrypted digital video from a Blu-ray disc to pass through any cable without HDCP encryption.
If Insignia is producing a BD player that plays over HDMI without HDCP encryption it will become a boat anchor as soon as Sony finds out about it. It will have its AACS keys revoked as soon as a new disc is inserted. | ||||||||
| the_importer posted 2008 Jun 29 23:11 | ||||||||
If that is true, then you have to ask yourself one crucial question, why do store even bother to advertise if a Blu-Ray player is HDCP compliant to begin with? | ||||||||
| jagabo posted 2008 Jun 29 23:51 | ||||||||
| So you're saying some Blu-ray players don't play BD-ROM? Then why do they bother mentioning it? And look -- the Insignia player doesn't support any HD codecs! That must mean it can only play SD BD discs.
Obviously, this is what happened: When Futureshop got their first BD player it came with a list of features. They used that list to generate the feature list form at their web site. That same list is used for all subsequent BD players that come in. Some marketing droid goes through each players documents and ticks the features off in the web form. When a player doesn't specifically mention one of the features the droid guesses. | ||||||||
| yoda313 posted 2008 Jul 03 18:06 | ||||||||
Thanks. I am interested in user reviews of the quality and ease of use of this feature. I'd love to have a petition website started to get this feature added to every movie. |
Login/Register to our forum to be able to post here.
