Hi!
I have a 30 minutes wmv concert, out of which I wanted to get a 7 minute song. The problem I'm having is that all of the softwares I have tried until now don't just chop off the unwanted minutes, they seem to want to reencode the file altogether.
My file is 37,5 Mb and, with the reencoding, even when chosing divX 5.0, the resulting file is larger than my full original (even though I choose the same width, height and frame rate).
Is there any program that just removes the bits I don't want to, without forcing me to choose formats?
Original wmv:
- Size: 37,5 Mb
Length: 30:11 minutes
Width: 320 px
Height: 240 px
FpS: 15
Bit Rate: 177 Kbps
Audio Sample Size: 16 bit
Channels: 1 (mono)
Audio Sample Rate: 16 kHz
Data Rate: 152 Kbps
Video Sample Size: 24 bit
Stream Name: video 2
Thanks in advance!
Results 1 to 11 of 11
Also the File Editor that comes with Windows Media Encoder (Version 9) lets you do basic cuts and does not reencode.
"Just another sheep boy, duck call, swan
song, idiot son of donkey kong - Julian Cope" -
Cut Assistant is a GUI for asfbin:
http://sourceforge.net/projects/cutassistant
If you enter "-rkf" as additional command line option for asfbin (Verion 1.5 or later), you can even cut on non-keyframe positions. NOTE: if you try -rkf and asfbin gives you this error: "Decompression error: VCM decoding driver is not available", the you must install the VCM driver from here:
http://www.microsoft.com/windows/windowsmedia/de/9series/codecs/vcm.aspx -
I'm trying to cut a .wmv of a stream downloaded from play.svt.se (a swedish tv channel)
However, asfbin keeps crashing during the cutting. I've tried both the GUI version (1.5) and the command line version (1.6). In the GUI version, I can load the file and choose a segment using the sliders, but get a crash when cutting. When using the command line version, and adding the -rkf parameter, I get the error BiggerJim mentions: "Decompression error: VCM decoding driver is not available". However, after I've installed wmv9VCMsetup.exe i still get the same error message.
Here's an example of such a wmv stream :
mms://qstream-wm.qbrick.com/00928/nyheter/2006/uttrar.wmv
Can someone help me find a way to cut files like that?
Do I perhaps have to do something else apart from just installing wmv9VCMsetup.exe (for example, do I have manually copy some of its files to the asfbin folder?)
I appreciate all help I can get!
EDIT:
this is what gspot says about the file:
FILE:
uttrar.wmv
3.37 MB (3,452 KB / 3,535,505 bytes)
CONTAINER:
File Type: ASF (.WMA/.WMV)
Mime Type: video/x-ms-asf
File incorrectly truncated.
· Original size:3.48 MB (3,569 KB / 3,655,129 bytes)
Sys Bitrate: 61 kb/s
USER DATA / METADATA:
AudeviceConformanceTemplate:L2
DeviceConformanceTemplate:L2
VideviceConformanceTemplate:MP@LL
DeviceConformanceTemplate:MP@LL
DeviceConformanceTemplate:MP@ML
Aud:WM/WMADRCPeakReference:27380
Aud:WM/WMADRCAverageReference:1462
WM/WMADRCPeakReference:27533
WM/WMADRCAverageReference:2065
WM/WMADRCPeakReference:27478
WM/WMADRCAverageReference:2067
Vid:Windows Media Video 9
Aud:Windows Media Audio 9.1
Aud: 48 kbps, 32 kHz, stereo 1-pass CBR
AUDIO:
0x0161 (WMA v2)
CBR
0x01:22050Hz 16 kb/s (1 chnl)
VIDEO:
WMV3
WMP v9 (VC-1 Simple/Main)
Codec Status Undetermined
176 x 144
1.222 (11:9)
EDIT2:
I did some more testing...
If I save the stream with SDP ( http://sdp.ppona.com/ ) asfbin can cut it. But SDP has no support for multiple stream downloading so a 1 hour stream takes 1 hour to download. In comparison, some download managers support multiple thread MMS downloading which is much faster. NetTransport (NetXfer) and ReGet are two examples. But files saved with both these applications crash asfbin. (The gspot data above is from the file that NetTransport saves.)
So maybe I should expand my question:
I'm looking for a multiple thread MMS downloader that outputs files that asfbin can handle. Or alternatively, some other asf cutter/joiner tool that supports the file that NetTransport or ReGet or some similar tool outputs.
I'd prefer if there was some way to get the files from NetTransport to be handled by asfbin. Is there perhaps some tool that can "clean up" the file before inputting it to asfbin? -
IMO of the situation, the problem is the source, it is encrpted or compressed for storage on the server, capturing the live realtime stream gives you the full correct stream, downloading/leeching the stream gives you the compacted stream, which cannot be edited
theewizard,
Well when I playback files saved through realtime and files saved through multiple threads I see no quality difference. So I think it's the "same" stream. The problem seems rather to be that it is incorrectly assembled in some way by NetTransport.
But I've found a solution now. I tried with some other download managers today and Flashget (
http://www.amazesoft.com/index_en.htm ) supports both 10 threaded downloads over MMS and outputs files AsfBin can handle (no VCM decoding drivers are needed).
So, problem solved! (by myself ) -
Try renaming from "whatever.asf" to "whatever.wmv".
Every "naturally-born" .wmv is in fact a .asf file.
Solved- How to do 2 -pass avi encoding with VirtualDub Mod
By jimdagys in forum Video ConversionReplies: 0Last Post: 22nd Nov 2009, 23:07 -
how to cut a wmv file
By stranzer in forum Video ConversionReplies: 5Last Post: 22nd Jun 2008, 11:26 -
[SOLVED] WMV to MPEG4/AVI/anything else has increasing audio desynch.
By Eilonwy05 in forum Video ConversionReplies: 13Last Post: 15th Jun 2008, 14:01 -
Solved: Can't Play WMV in IE with Media Player Classic.
By DarrellS in forum Software PlayingReplies: 0Last Post: 13th May 2008, 11:31 -
How can i cut out a scene from a wmv?
By denadel in forum Newbie / General discussionsReplies: 4Last Post: 22nd Nov 2007, 08:25
