Forum archive - SAMSUNG camera LCD white screen
http://www.supermediastore.com/
Forum Archive Home -> Camcorders (DV/HDV/AVCHD) -> SAMSUNG camera LCD white screen
szalaikornel posted 2009 Oct 19 13:21
My LCD screen is always white! Any ideas what can be the problem?
THANKS!
edDV posted 2009 Oct 19 14:03
Can you get picture in the viewfinder?
If so, my guess is the LCD has a detached or shorted cable.
szalaikornel posted 2009 Oct 19 15:23
Yes, I have picture in viewfinder. I think so that the cable is a problem. Can be anything other the problem?
edDV posted 2009 Oct 19 16:06
szalaikornel :
All you can do is wiggle it from the outside. A local camcorder repair shop should be able to fix it and cheaper than "factory service" flat rates.
It could be a failed module but that is less likely than a connector issue.
Camcorders are difficult to self service. You may do more damage.
filmboss80 posted 2009 Oct 19 16:18
Check your owner's manual. In low-light settings, many camcorders have a feature that turn the flip-out screen into a type of light to better illuminate the shot. (Of course, the screen should be rotated toward the subject in that case.) I don't know about your particular model, but I'm guessing it is set as a light instead of a view screen.
Login/Register to our forum to be able to post here.
Replay Video Capture, if you can Watch it, you can Capture it ! and save it to your computer. More info or download trial!
About   Advertise   Forum Archive   RSS Feeds   Statistics
