Forum Archive Home -> Video Streaming -> S-Video Help
S-Video Help |
| Doowop posted 2009 Sep 16 21:13 |
| Okay a few weeks ago i bought a 4-pin (on both sides) s-video cord and i plugged one side into an output insert on my Scientific Atlanta 3200HD Cable box and plugged the other into my laptop and i was wondering if i could send the video feed to my computer just to watch it completely no recording like in other words possesing my pc monitor
[Cable Box]______{S-Vid4-pin}______[Laptop] ( Sending the display from the cable box to my laptop ) You get it? Other notes I have composite connected to my tv from the cable box would i have to take them out first? Sorry I'm a Complete Newb when it comes to TV Audio And Cords. ![]() |
| Bodyslide posted 2009 Sep 16 21:23 |
| Mkae sure the S-Video connection on your laptop can receive video.. Normally the S-video on Laptops are for sending out video only..
The S-Video only does video, you you also need to use the audio out from the box to the the laptop. Good Luck |
| jagabo posted 2009 Sep 16 21:26 |
| You need a USB video capture device.
http://www.tigerdirect.com/applications/category/category_slc.asp ... %20Devices |
| Doowop posted 2009 Sep 21 16:21 |
| Thanks it just pruchased one and its working perfectly ^^ |
| jagabo posted 2009 Sep 21 16:26 |
| Which one? It might help others who are looking for one. |
Login/Register to our forum to be able to post here.
