VideoHelp.com forum archive
http://www.supermediastore.com/
Forum Archive Home -> Video Conversion -> rmvb format to mpeg conversion
sumeshkri posted 2008 Sep 29 02:15
i have got some RMVB files. How to convert them to MPEG? thanks in advance.
guns1inger posted 2008 Sep 29 02:20
ConvertXtoDVD
sumeshkri posted 2008 Sep 29 02:59
thanks a lot. have a nice day
sumeshkri posted 2008 Oct 01 16:41
i have converted the RMVB file to vob using convertxto dvd. the product does n ot synchronize. the audio is played after the visuals disapper. it is delayed. i could not check the rmvb file because it does not play with jetaudio. i demultiplexed. the video length is 01-04-01 whereas the audio is 01-04-05(h-m-s).any help to make the vob synchronized? thanks
45tripp posted 2008 Oct 01 17:36
you'll want to install realplayer,
or realalternative,
then avisynth.
and try frameserving with directshowsource()
will probably work.
if you're up to trying.
i'll type more
mgh posted 2008 Oct 01 23:32
Do the following
1. get real producer basic (free) from real and install.
2. in rpb-file-edit real media file-new window opens
3. Load your rmvb in the editing window.
4. There are two buttons with double arrows-one for forward, other for backward
5. first click the forward button once and then the backward button. Set that as start point
6. go to end of video. click backward button once and then the forward button once. Set that end point.
7. Your selection starts and ends with I frames.
8. Save it as a new rmvb file.
Try loading the new rmvb file in convetrtxtodvd and see what happens. if you still have problems, you will need to use avisynth.
sumeshkri posted 2008 Oct 02 00:41
thanks for the suggestions.
whatsmyname posted 2008 Oct 02 03:55
I have also used ConvertXtodvd before, some files do suffer out of sync audio. I have also used avisynth, also with mixed success, sometimes avisynth won't load the movie at all (but that movie works in Convertx)
I had to use a mixture of convertx and avisynth to successfully convert about 5 rmvb files to mpeg2.
Good luck.
Login/Register to our forum to be able to post here.
About   Advertise   Forum Archive   RSS Feeds   Statistics
