Forum archive - Reversing Hack on DVD Player Phillips DVDR3460
http://www.supermediastore.com/
Forum Archive Home -> DVD & Blu-ray Players -> Reversing Hack on DVD Player Phillips DVDR3460
bricanbrac posted 2009 Oct 13 19:49
I have used the Hack on my Phillips DVDR3460 DVD player to make it take Region 2, now it will not play other regions. How do I reverse this Region 2 Hack.
Please any help.
Ai Haibara posted 2009 Oct 13 19:59
Try the hack/code again, except this time, set it either to Region 0 or your correct region.
jagabo posted 2009 Oct 13 19:59
Set it to region 0 and it will play all discs.
bricanbrac posted 2009 Oct 13 20:05
Hi,
I thank you for your reply, but I am not sure what number to change.
This is what I did to do the hack.
Connect and turn on TV and DVD player
- With no disc inserted, select ‘system menu’ on the remote control
- Enter these numbers *SLOWLY* on the remote control: 5, 0, 1, 8, 0
- Press ‘OK’
WHICH NUMBER DO I CHANGE.
jagabo posted 2009 Oct 13 20:16
Probably the last digit (other Philips units are like that). But that would mean you set it to region 0 already and it should play everything except region 1 discs with RCE protection. I believe Australia is region 4.
Ai Haibara posted 2009 Oct 13 21:20
Well, according to this page:
http://www.videohelp.com/dvdhacks/philips-dvdr3460/8641
...it should pop up a menu showing the region selection after you enter 50180 (but before pressing OK).
jagabo posted 2009 Oct 13 21:46
Ai Haibara :
That's the way I read it at first. But I decided that what it probably meant was there would be a status page showing the region code that was selected.
Ai Haibara posted 2009 Oct 13 23:08
Maybe. It's hard to tell without having the player around to look at, of course. :)
It probably shouldn't behave that much differently from, say, the 642, or the 5990, in theory. :)
Login/Register to our forum to be able to post here.
VSO Software ConvertXtoDVD lets you convert any video like AVI,MKV to DVD easily. More info or download trial!
About   Advertise   Forum Archive   RSS Feeds   Statistics
