Forum archive - restoring an old VHS
http://www.supermediastore.com/
Forum Archive Home -> Restoration -> restoring an old VHS
antoniomch posted 2009 Aug 28 17:10
Hi
Is there an easy noob way to enhance an old VHS movie that I already converted to mpg ?
jagabo posted 2009 Aug 28 18:05
Maybe. What's wrong with it?
lordsmurf posted 2009 Aug 28 22:44
Describe the problems.
antoniomch posted 2009 Aug 29 07:01
Some parts of the film are very white, but all the film is very "blurry"
I've attached a sample
On the left shows what happened in some sections of the video
The other image shows how the rest of the movie is, too blurry. There are some sections worst then on this image.
I can digitallize the video again, since I have the tape, and I still own a functional VHS
Probably there is something I can do to make a better mpg file, before I enhance it.
Note:
I'm not a noob in the computer world, but I'am a noob, very noob, in video editing/processing...
guns1inger posted 2009 Aug 29 07:11
If that is what the tape looks like then you will have problems getting much out of them. The whites look very hot, so there is little to no detail left in them to restore.
dphirschler posted 2009 Aug 29 08:27
Looks like you will be capturing again. You need to spend some time tweaking your capture settings. Bring contrast down and set gamma at 1 (or 100% which ever your software calls it). If there is a setting for "gain" then you will want to bring it down as well.
Darryl
lordsmurf posted 2009 Aug 29 08:45
Sometimes consumer VCRs overly add contrast, and then some capture devices will do this to video it thinks have "copy protection" (even if it's homemade, obviously).
jagabo posted 2009 Aug 29 09:09
To get really great captures you'll need a good S-VHS deck with line time base correcter, noise filtering and sharpening; a full frame time base corrector; and a video processing amplifier to adjust levels and colors. All that will cost you about US$1000. Then you'll probably have to capture shot by shot with adjustments taylored for each shot.
If you are unwilling to purchase all that equipment you can at least adjust the levels (brightness, contrast) at your capture device. That will hopefully get you some details in the washed out bright areas and better contrast. If you can, capture uncompressed or losslessly compresssed (huffyuv, lagarith). That will allow you to run sharpening and other filters without accentuating the MPEG artifacts. But there's a limit to how much you'll be able to sharpen without making the video look worse.
Login/Register to our forum to be able to post here.
DVDFab DVD to DVD and Blu-ray to Blu-ray offers a 20% discount until Nov 22, 2009. More info or download trial!
About   Advertise   Forum Archive   RSS Feeds   Statistics
