VideoHelp.com forum archive
http://www.supermediastore.com/
Forum Archive Home -> DVD to AVI/MP4/WMV/MKV -> Resolution problems when converting with FUW
Malicious posted 2008 Aug 07 23:09
I have tried many different combinations of resolutions to remove the jagged lines from the picture. I get it into FUW and FUW will say the video is at 704x480 for example and when I encode it to that resolution I get the jagged lines. Now when I put the same DVD into DVDFab it gives me a resolution of 624x464 and I do not get the jagged lines.
I would use DVDFab more often if the software had the option to bob deinterlacing like FUW does. Is there something I am doing wrong to get this?
Edit: I guess my real problem is that DVDFab defaults to the correct resolutions while FUW does not. Without my trial of DVDFab I would not be able to determine the correct resolutions from some of my dvd's. Is there some setting in FUW to change it?
Malicious posted 2008 Aug 08 01:02
To show what I mean I have uploaded a picture. The VLC player is playing the FUW rip at 640x480. The WMPC is playing the DVDFab rip at 640x480. These are both ripped at 1100 Kb/ps. As you can see there are jagged lines along the black outlines of everything drawn on the FUW rip. What can I do to prevent this from happening?
Login/Register to our forum to be able to post here.
About   Advertise   Forum Archive   RSS Feeds   Statistics
