Forum Archive Home -> Video Conversion -> resizing with RIPBOT
resizing with RIPBOT |
| Benjy posted 2009 Oct 31 12:31 |
| I want to know if it is possible to resize a converted file using Ripbot 264...
I know to use RipBot , but I didn't find the button for resize , I mean from 14Gb to ...2 Gb , let's say.. 10x ! |
| Baldrick posted 2009 Oct 31 18:58 |
| Under the Encoding settings change the "Mode" to 2-pass and you can set the "Lock size" to anything you want. |
| Benjy posted 2009 Oct 31 23:36 |
| Thanks Baldrick
I found that button ,but how can I set the size ??? with that command I can establish only the WIDTH ( 1980-->1280) but no HEIGHT ( 1280-->720 ) - I suppose it is doing automatically by choosing the aspect ratio ( 16 : 9 ), but how can I set the stream size ??...I need a bitrate calculator , or smth like MeGui uses , to set a 24 GB file to 2 GB ,let's say... PS :Do not forget : this Forum is a real help for anyone..It was a great ideea to open it...congratulations !!! |
| redwudz posted 2009 Nov 01 01:37 |
| I think you have the wrong button. You want to set the output size of the file?
Resizing generally refers to the frame size, 1920 X 1080 or so. The output size is set here: :( ![]() |
| Benjy posted 2009 Nov 01 01:52 |
| @redwudz
Thanks !! That was.... |
| Baldrick posted 2009 Nov 01 03:36 |
| Did you even read my post...;)...or well I guess the lock size(mb) is a bit strange placed. |
| Benjy posted 2009 Nov 01 04:47 |
| yes Baldrick , but is a little strange...sometimes dissapeares "lock size "if "2pass" is not selected , and this confused me :(...now is at all OK , even the output size has fixed parameters ( 700 MB , 4480 MB , 8150 ,aso)..
If I want to select 2GB or 2,3 GB so that on a DVD 5 can enter 2 such files , is impossible.... 10x anyway !! |
| redwudz posted 2009 Nov 01 11:49 |
| You can type in '2000' (2GB) in the 'Lock Size' window, then it will use that as an output size. A standard DVD-5 will only hold about 4.37GB, so I wouldn't go much higher than 2GB if you want two files on a DVD-5. |
| Benjy posted 2009 Nov 01 12:20 |
@redwudz
@Baldrick ![]() |
| Atak_Snajpera posted 2009 Nov 01 16:41 |
| >>yes Baldrick , but is a little strange...sometimes dissapeares "lock size "if "2pass" is not selected , and this confused me <<
Since when you can predict size in Constant Quality mode (CRF)??????????? This options disappeares because it CANNOT BE USED!!!!! Do you understand now!?!? If I left this option visible all the time it would be even more confusing! |
| Benjy posted 2009 Nov 02 00:54 |
| @Atak_Snajpera
Yes , you are perfectly right...Now I understand the operation mechanism..
THANKS !!!! Yet I have a question: I have a 22 GB file that I set it to be encoded to 2 GB mkv format, 1280/720, 16:9 ... At PASS 1 it will be finished after 10 hours and at PASS 2 in 13 hours ... now is the second time when I do this operation because the first time was blocked and had to restart ... so hard to make it work?? I remember other films went much faster even they had the same size and in maximum 4-5 hours the soft finished it's job.... |
Login/Register to our forum to be able to post here.
