VideoHelp.com forum archive
http://www.supermediastore.com/
Forum Archive Home -> SVCD2DVD General -> Removing channel info !!
Siddus posted 2008 Aug 23 06:17
Is there any way that I can remove the irritating channel info on my hd movies ???
I have a few episodes of Stargate Atlantis from sci-fi channel and they all display channel info and other
channel commercials.
All help in this matter is appreciated.
Siddus
jman98 posted 2008 Aug 23 08:40
We need a beter explanation. You seem to have 2 completely different things that you want to do. By "channel info" do you mean a channel logo? If that's what you mean, there are filters for AVI files that can remove it, but I'll warn you that all it does is leave a fuzzy spot where the logo was in the exact same shape as the log. Some Russian website that claims to have a filter that can completely remove logos uses doctored photos to support their claim on how the filter works. Don't believe it. I also don't recommend you get any software from Russia that claims to do it unless you are willing to submit it to an anti-virus scan prior to installing.
Removing commercials requires you to edit. There are a variety of editors available for MPEG-1/2 video. VideoReDo and MPEGVCR are not free, but both are excellent and both are "try before you buy". I feel very firmly that if you use a freeware editor (there are a few) that you get what you pay for (that means I think they suck). However, a few people do actually like the freeware editors, so you could try them and see what you think.
Editing commercials doesn't require your video to be re-encoded, but trying to remove a logo will. Re-encoding generally makes the quality worse, but it is possible to encode losslessly to AVI, but you'll then have to re-encode that back to MPEG-2 for DVD and that won't be lossless.
Siddus posted 2008 Aug 25 01:11
My HD-movies are in .mkv format and they contain both the irritating channel logo that sci-fi channel uses and some type of commercials/infostrips that sci-fi channel also uses during there shows..
I hope that this makes it bit clearer as to what I am trying to do.
English is not my native language, I am swedish, so there might be some confusing writing here and there :oops:
Siddus
usually_quiet posted 2008 Aug 25 11:21
The situation regarding static channel logos/watermarks has been explained already. Animated logos and pop-up advertisements overlaying programming can't be removed.
If you want a pristine HD picture, you'll need to obtain a Blu-Ray version.
Login/Register to our forum to be able to post here.
About   Advertise   Forum Archive   RSS Feeds   Statistics
