Forum archive - registration problem SVCD2DVD
http://www.supermediastore.com/
Forum Archive Home -> SVCD2DVD & VOB2MPG -> registration problem SVCD2DVD
stgreene posted 2009 Oct 30 21:39
I have donated and registered for the SVCD2DVD. When I click the icon and follow the registration instructions using the serial number information provided as instructed upon registration. After clicking register, nothing happens, the box disappears and I cannot run the software. If I click on the icon again, the same thing happens over and over.....Please advise.
lowellriggsiam posted 2009 Oct 30 22:20
1 try rebooting
2 try disabling your firewall
Wizard23 posted 2009 Oct 30 23:55
If your on vista right click on svcd2dvd and choose run as administrator. And it will register for you. I hope this helps.
stgreene posted 2009 Oct 31 19:33
Thank you both for your help:
lowell- i tried both and neither work. same thing happens
Wizard- when I right click, that is not an option. I go into properties and run as administrator is grayed out....run in separate memory space is checked. But this feature appears to be locked...any ideas?
redwudz posted 2009 Oct 31 20:56
You would get more answers in our SVCD2DVD & VOB2MPG Forum. Moving you. :)
stgreene posted 2009 Oct 31 21:00
Thanks Redwudz!!! :D
ChrissyBoy posted 2009 Nov 01 12:16
As you have vista - can you take a look at this thread about installation and Vista issues?
http://forum.videohelp.com/topic324278.html#1776530
(In particular: installation in a folder other than "Program Files" and running "As Administrator")
stgreene posted 2009 Nov 08 00:15
ChrissyBoy,
I cannot locate the exe file in the folder for SVCD2DVD v2.5. I do not think that it came over when I downloaded and installed this software.
I have an exe.config file, but I can't seem to open it. Is it possible that I can redownload and install it, without having to pay for this twice?
stgreene posted 2009 Nov 08 00:29
nevermind! Thanks got it to work.....Thanks for all your help!!! :D
Ai Haibara posted 2009 Nov 08 00:32
Do you have "Hide extensions for known file types" enabled in Explorer?
(In Explorer, go to Tools > Folder Options > 'View' tab. Make sure the checkbox next to "Hide extensions for known file types" is not checked.)
Then, see if the .exe file is present in the SVCD2DVD directory. :)
(Edit: Oops, too late. :D )
Login/Register to our forum to be able to post here.
DVDFab DVD to DVD lets you backup DVDs to DVDr, AVI or MP4 for portable devices. More info or download trial!
About   Advertise   Forum Archive   RSS Feeds   Statistics
