Forum archive - Red Flashes
Forum Archive Home -> Authoring (DVD) -> Red Flashes
Red Flashes
gerritv posted 2009 Oct 27 00:42
Hi Everyone,
I finally managed to edit my video files off my sony camcorder.
I used Adobe Premiere Pro CS3 to edit and add text to the video also adding chapter markers.
(What is the best settings to use when exporting to Adobe Encore CS3, like quality and filtering etc)
Then I used Adobe Encore to create my menu and burn to DVD. The problem is every now and then during the video playback a red screen would flash for a fraction of a second.
What is this? On the original files in Premiere it doesn't happen only after exporting?
Regards
G
Bjs posted 2009 Nov 12 03:35
From adobe forum
By design to indicate bad / corrupted frames
Login/Register to our forum to be able to post here.
Replay Video Capture, if you can Watch it, you can Capture it ! and save it to your computer. More info or download trial!
About   Advertise   Forum Archive   RSS Feeds   Statistics
