Forum archive - Recording TV -> burning DVD -> storing on PC -> rebuilding DVD
http://www.supermediastore.com/
Forum Archive Home -> DVD Ripping -> Recording TV -> burning DVD -> storing on PC -> rebuilding DVD
ipolicky posted 2009 Oct 26 10:28
Hi all,
I often record TV programs by DVD recorder and then make DVD from them. I would like to store these DVDs on my PC. I am able to play these DVDs in a player on PC. But would be great if such DVD can be rebuild after months or years so that it is playable on the DVD player as well.
Can anybody recommend me some tools for this if some exist (I mean a tool for backing up DVD, a tool for playing DVD on PC and a tool for burning DVD from the copy stored on PC)
At the moment I simply copy DVD on harddisc, play it by MS MediaPlayer or VLC and am not able to recreate original DVD... I am not satisfied with the way VLC plays these DVD copies...
I'd love to hear from anybody who thinks can help me.
ipo
Baldrick posted 2009 Oct 26 13:13
I would rip the DVD to one ISO file using ImgBurn, then play the iso in VLC or you can mount the iso as virtual dvd drive. And can you easily burn the iso on dvdr to get them back.
ipolicky posted 2009 Oct 27 05:16
Thanks a lot, I'll try it
ipo
Login/Register to our forum to be able to post here.
Replay Video Capture, if you can Watch it, you can Capture it ! and save it to your computer. More info or download trial!
About   Advertise   Forum Archive   RSS Feeds   Statistics
