hi ,
i live in the middleast and i have many vhs tapes that are secam .
and i want to digitize them by converting them to dvd .
the problem i am facing is that the panasonic dmre100 dvd recorder that i have doesn't record secam signal ( the picture appear black and white ) .
so my question is there a dvd recorder that records secam ?
thanks
I'm not sure if it is still made, but I have the Panasonic AG-W1 which will not only playback in SECAM but also through convert (convert it while playing back) on the fly.
E-Bay has a few used AG-W1's and also the AIWA HV-MX1. The problem is neither ship outside of the USA or Canada. Ah! Here is a Panasonic deck which ships worldwide. Hope this helps. -
I can vouch for the AG-w1. I used one 15? years ago. I cant believe they still make it, but if you can find a used one, it might be worth a try. I rented mine at a local video store, for something like $30?/day. I did all my conversions from PAL VHS to NTSC VHS. Worked like a charm.
Never used the Aiwa, but I heard good reviews about it. I would say the Panny is defiantly a commercial unit, while the Aiwa is more consumer.
PAL DVD work on SECAM?
By BobAchgill in forum Authoring (DVD)Replies: 3Last Post: 4th Aug 2009, 06:20 -
VHS capture jumping between PAL and ME SECAM...help
By pijetro in forum CapturingReplies: 2Last Post: 21st Feb 2009, 18:55 -
NTSC in an area where Secam is used?
By B-Twien Bytes in forum Newbie / General discussionsReplies: 0Last Post: 2nd Jan 2009, 07:14 -
How can one convert WMV to SECAM?
By fledermaus in forum Video ConversionReplies: 1Last Post: 7th May 2008, 20:05 -
Can Secam Varieties Be Played Interchangeably?
By moviebuff2 in forum Newbie / General discussionsReplies: 4Last Post: 10th Jul 2007, 17:04
