VideoHelp.com forum archive
http://www.supermediastore.com/
Forum Archive Home -> Video Conversion -> Recommend a GUI for FFmpeg
David_UK posted 2008 Oct 01 08:04
Hi all
Can you recommend a GUI for ffmpeg that would fulfill these criteria?
1. I don't have installation rights, so it needs to be a stand-alone app.
2. I want to be able to queue up the jobs and leave the conversion running while I get on with other stuff.
3. I want to convert to a -sameq mpeg, ready for editing in VirtualDub or WMM.
I thought that WinFF was ideal, but I don't think I can select MPG as the output (unless I choose a target format like VCD).
Many thanks in advance.
45tripp posted 2008 Oct 01 08:37
Avanti
if you need help setting up the template let me know
t0nee1 posted 2008 Oct 01 08:58
In WinFF, if you pick DVD format you'll get your mpg,ready for editing in VD, but you do know you'll need the mpeg.vdplugin to import .mpg in VD right? You could also use VirtulaDub MPEG2............
David_UK posted 2008 Oct 01 15:16
45tripp
Nice! Thanks so much. Took a while to work out how to make a template so I could use job control, but it's just what I want - thanks.
t0nee1, thanks, but I don't want to change the video dimensions, and I think using the DVD target would do that.
Login/Register to our forum to be able to post here.
About   Advertise   Forum Archive   RSS Feeds   Statistics
