This one is just so odd that if I hadn't seen it with my own eyes I'd never believe it.
I do a lot of temporary burns onto DVD-RWs with episodes of TV shows. For this I have a default menu with a background bitmap and I manually set the font to Tahoma, Bold Oblique, 24 point each time. Most times each disc ends up with three or four episodes. Occasionally it's just the one episode but either way I align all of the text 'buttons' vertically (if there's more than one) then use the centre horizontally and centre vertically buttons to put everything in the middle of the 16:9 frame.
Yesterday I tried doing this with a single episode and SVCD2DVD crashed during the Encoding Menu phase. The whole program just disappeared, interface and all. At first I thought this must be a problem with the video itself so I tried trimming the temporary MPG file and trying again, but it still crashed. Then I tried obtaining another copy of the *ahem* 'source' AVI and started again. Still it crashed.
This could have continued all day but during one of the many attempts I accidentally forgot to set the font to Tahoma, Bold Oblique 24 and SVCD2DVD reported success. Not quite able to believe how a font setting could upset the disc creation I tried again with the font set how I normally do things, and it crashed.
I tried again with the almost the same settings but with the font set to 26 point. The disc was created successfully. Then I tried again with a different font. Success. Then I set it for Tahoma, Bold Oblique 24 but added an extra character to the episode title. Success. Finally I tried the original title, Tahoma Bold Oblique 24, but offset the button from exact centre. Incredibly, it succeeded again. Just to make sure I wasn't going nuts I put everything back the way it was with the button centered, and it crashed.
There must be a unique combination of character length, font size, button position and possibly the background bitmap that's causing an internal problem for SVCD2DVD or one of the other programs whose functions it calls. I'm attaching a couple of log files, one from a successful run with the menu text offset and another from a bad run with the text centred.
Hopefully someone here can translate these log files better than I can and help come up with an explanation. The only difference I can see is in the HERE WE GO EVE.ODD section where the 'bad' configuration leads to a couple of zeroes while there aren't any in the 'good' configuration. I don't know exactly what's going on here but zeroes where there shouldn't be generally don't bode well in computing!
As you can see, the final line of the 'bad' log shows a missing temporary file. I'm guessing it's this that's causing SVCD2DVD to fall over, but it would be nice to know exactly what the mechanism is that's leading to it. The workaround is obvious -- if it crashes, move the text and try again -- but I abhor mysteries. In many years of using this program with these or very similar settings this is the first time I've seen such a thing happen.
Anyway, here are the logs. First the working configuration...
************************ SYSTEM INFORMATION ************************
***************************** SVCD2DVD *****************************
Title: 2.5
Version: 2.5.5030.0
Executable: C:\Video\SVCD2DVD\SVCD2DVD.exe
Executable size: 2.58 MB
Executable size in bytes: 2711635
Executable CreationTime: 28/01/2009 15:57:36
Executable LastWriteTime: 23/08/2009 15:24:09
Executable LastAccessTime: 23/08/2009 15:24:09
************************* Operating System *************************
Operating System: Microsoft Windows 7 Ultimate
Service Pack:
Version : 6.1.7100
Windows Directory : C:\Windows
OSLanguage: 1033
CodeSet: 1252
CountryCode: 44
Local: 0809
Total Physical Memory: 3.99 GB
Free Physical Memory: 2.48 GB
Total Virtual Memory: 7.99 GB
Free Virtual Memory: 6.20 GB
***************************** Computer *****************************
Computer Manufacturer Name: HP-Pavilion
Computer Model: KZ756AA-ABU m9351.uk
System Type: x64-based PC
Computer Name: REDACTED
DomainRole: x2c3419cdc9b8e007
Number Of Processors: 1
User Name: REDACTED\REDACTED
***************************** Processor ****************************
Manufacturer: GenuineIntel
Processor: Intel(R) Core(TM)2 Quad CPU Q6600 @ 2.40GHz
Description: Intel64 Family 6 Model 15 Stepping 11
CPU Speed: 2.4GHz
CPU FSB: 1.066GHz
L2 Cache Size: 8.00 KB
15:11:03: Logical CPUs: 4
***************************** Time Zone ****************************
Time Zone: (UTC) Dublin, Edinburgh, Lisbon, London
****************************** VIDEO *******************************
Name: NVIDIA GeForce 9600 GSO 512
Processor: GeForce 9600 GSO 512
Mode: 1440 x 900 x 4294967296 colors
Video Ram: 1.00 GB
Status: OK
****************************** Drives *******************************
DeviceID: C:
FileSystem: NTFS
FreeSpace: 7.08 GB
DeviceID: D:
FileSystem: NTFS
FreeSpace: 132 GB
DeviceID: E:
FileSystem: NTFS
FreeSpace: 29.8 GB
DeviceID: F:
FileSystem: NTFS
FreeSpace: 52.5 GB
********************* END OF SYSTEM INFORMATION ********************
************************* ProjectMetaData **************************
<?xml version="1.0" encoding="utf-8"?>
<SVCD2DVD DateTime="03/10/2009 15:11:04" Filename="NONE">
<AssetSet>
<Asset ID="3921fbae-49e9-4d7b-af3f-040a8005a408" Path="F:\" Filename="5x03 - The Plain In The Prodigy_S2D.mpg" />
</AssetSet>
<DVDStructure>
<TitleSet Name="5x03 - The Plain In The Prodigy" PostCmd="" MenuButtonType="0">
<MenuButton X1="159" Y1="158" X2="693" Y2="204" FontFamily="Tahoma" FontSize="24" FontStyle="3">5x03 - The Plain In The Prodigy</MenuButton>
<Title Name="5x03 - The Plain In The Prodigy_S2D.mpg" AssetID="3921fbae-49e9-4d7b-af3f-040a8005a408" MplexOffset="0" />
</TitleSet>
<DVDMenu Normal="-4144960" Highlight="-1" Active="-16777216" ShowPlayAllButton="False" DSOffsetWidth="1" DSOffsetHeight="1" DSColor="0" DSOnOff="True" BackgroundImagePath="F:\Projects\Metallic.bmp" AudioPath="" />
</DVDStructure>
<Settings>
<General InitialAssetFolder="F:\" InitialDVDFolder="F:\" OutputFolderName="SVCD2DVD_OUTPUT" InitialProjectFolder="F:\Projects" InitialMenuBackgroundFolder="F:\Projects" DeleteS2DFiles="False" UseDVDShrink="False" />
<Menu AudioEncoding="Custom_ac3" DefaultCustomAudioPath="" DefaultCustomImagePath="F:\Projects\Metallic.bmp" TVStandard="NTSC" FontFamily="Tahoma" FontSize="15.75" FontStyle="3" PlayAllText="Play All" Loop="True" ShowMenuStandardWarning="True" EncodeVideo2AudioDuration="True" MenuAspectRatio="AR_16_9" />
<Process AudioEncoding="ac3" Chapters="Every 5 mins" SkipMPA48="False" SkipAC3="True" PanSan="False" MergeTitles="False" UsePulldown="True" PAL2NTSC="False" AVI2PASS="False" AVI2HALFD1="FS" NoBframes_FullME="False" UseCustomMatrices="False" IntraMatrix="" NonIntraMatrix="" TVOverscanPixels="0" UseThreads="True" ForceWS="False" SafeMaxBitRate="False" OrderAudioStreams="False" ProcessIfNavPacks="False" />
<Program BINExtraction="vcdxrip" VCDGearFIX="False" FastAudioEncode="True" />
<Burning BurningMethod="NONE" ImgBurnPath="" DVDDErase="True" DVDDClose="False" DVDDDontBurn="False" />
</Settings>
</SVCD2DVD>
Processing assets for DVD creation
=================== AV Details ===================
File Size: 2.17 GB
file=F:\\5x03 - The Plain In The Prodigy_S2D.mpg
FormatName=mpeg
Num_Frames=62000
DurationInSecs=2586
Duration=00:43:05.9
VideoCodec=mpeg2video
VideoFFSTNum=0
Width=720
Height=480
Standard=NTSC
BitRate=7240
AudioStreamCount=1
Audio1FFSTNum=1
Audio1StreamID=[0x80]
Audio1SampleRate=48000
Audio1Codec=ac3
Audio1BitRate=448
Audio1Channels=6
15:11:04: Leaving 5x03 - The Plain In The Prodigy_S2D.mpg alone. File has Nav Packs
15:11:06: Done: Processing assets for DVD creation
Authoring DVD Folders
15:11:06: Creating TitleSet # 1
15:11:06: SVCD2DVD: DVDfolders
Generating DVD folders please wait....
15:11:06: -->: DVDFolders creating VTS
15:11:06: -->: VTS 01
15:11:06:
DVD Folders: Processing C:\Video\SVCD2DVD\dummymenuNTSC.mpg...
15:11:06:
DVD Folders: Processing F:\5x03 - The Plain In The Prodigy_S2D.mpg...
15:12:19:
15:12:19:
15:12:20:
15:12:20: Finalising DVD...
15:12:20: Encoding menu...
---------------------------- ENCODING MENU ----------------------------
TV Standard: NTSC
Aspect Ratio: 16:9
Image size: 960x540
Resize size: 720x480
[] 15:12:20: FFmpeg version UNKNOWN, Copyright (c) 2000-2008 Fabrice Bellard, et al.
[] 15:12:20: configuration: --disable-debug --disable-vhook --enable-avisynth --enable-gpl --enable-pthreads --enable-libfaad --enable-memalign-hack --enable-swscale --disable-devices
[] 15:12:20: libavutil 49.12. 0 / 49.12. 0
[] 15:12:20: libavcodec 52. 6. 0 / 52. 6. 0
[] 15:12:20: libavformat 52.23. 1 / 52.23. 1
[] 15:12:20: libavdevice 52. 1. 0 / 52. 1. 0
[] 15:12:20: libswscale 0. 6. 1 / 0. 6. 1
[] 15:12:20: built on Dec 7 2008 19:00:16, gcc: 4.3.0 20080305 (alpha-testing) mingw-20080502
[] 15:12:20: Input #0, image2, from 'C:\\Users\\REDACTED\\AppData\\Local\\Badger I.T.\\SVCD2DVD 2.5\\2.5.5030.0\\menu\\background1.jpg':
[] 15:12:20: Duration: 00:00:00.04, start: 0.000000, bitrate: N/A
[] 15:12:20: Stream #0.0: Video: mjpeg, yuvj420p, 720x480 [PAR 96:96 DAR 3:2], 25.00 tb(r)
[] 15:12:20: Output #0, rawvideo, to 'C:\\Users\\REDACTED\\AppData\\Local\\Badger I.T.\\SVCD2DVD 2.5\\2.5.5030.0\\menu\\backgroundES.mpv':
[] 15:12:20: Stream #0.0: Video: mpeg2video, yuv420p, 720x480 [PAR 32:27 DAR 16:9], q=2-31, 6000 kb/s, 29.97 tb(c)
[] 15:12:20: Stream mapping:
[] 15:12:20: Stream #0.0 -> #0.0
[] 15:12:20: Press [q] to stop encoding
[] 15:12:20: video:49kB audio:0kB global headers:0kB muxing overhead 0.000000%
15:12:20: INFO: [???] mplex version 2.0.0 (2.2.3 $Date: 2004/01/13 20:45:26 $)
15:12:20: INFO: [???] File C:\Users\REDACTED\AppData\Local\Badger I.T.\SVCD2DVD 2.5\2.5.5030.0\menu\backgroundES.mpv looks like an MPEG Video stream.
15:12:20: INFO: [???] Video stream 0: profile 8 selected - ignoring non-standard options!
15:12:20: INFO: [???] Found 0 audio streams and 1 video streams
15:12:20: INFO: [???] Selecting dvdauthor DVD output profile
15:12:20: INFO: [???] Multiplexing video program stream!
15:12:20: INFO: [???] Scanning for header info: Video stream e0 (C:\Users\REDACTED\AppData\Local\Badger I.T.\SVCD2DVD 2.5\2.5.5030.0\menu\backgroundES.mpv)
15:12:20: INFO: [???] VIDEO STREAM: e0
15:12:20: INFO: [???] Frame width : 720
15:12:20: INFO: [???] Frame height : 480
15:12:20: INFO: [???] Aspect ratio : 16:9 display
15:12:20: INFO: [???] Picture rate : 29.970 frames/sec
15:12:20: INFO: [???] Bit rate : variable
15:12:20: INFO: [???] Vbv buffer size : 212992 bytes
15:12:20: INFO: [???] CSPF : 0
15:12:20: INFO: [???] SYSTEMS/PROGRAM stream:
15:12:20: INFO: [???] rough-guess multiplexed stream data rate : 0001248
15:12:20: INFO: [???] target data-rate specified : 10080000
15:12:20: INFO: [???] Setting specified specified data rate: 10080000
15:12:20: INFO: [???] Run-in Sectors = 88 Video delay = 12873 Audio delay = 15876
15:12:20: INFO: [???] New sequence commences...
15:12:20: INFO: [???] Video e0: buf= 0 frame=000000 sector=00000000
15:12:20: INFO: [???] STREAM e0 completed @ frame 14.
15:12:20: INFO: [???] Multiplex completion at SCR=4096.
15:12:20: INFO: [???] Video e0: buf= 49929 frame=000014 sector=00000026
15:12:20: INFO: [???] VIDEO_STATISTICS: e0
15:12:20: INFO: [???] Video Stream length: 50472 bytes
15:12:20: INFO: [???] Sequence headers: 2
15:12:20: INFO: [???] Sequence ends : 0
15:12:20: INFO: [???] No. Pictures : 15
15:12:20: INFO: [???] No. Groups : 2
15:12:20: INFO: [???] No. I Frames : 2 avg. size 16289 bytes
15:12:20: INFO: [???] No. P Frames : 14 avg. size 1239 bytes
15:12:20: INFO: [???] No. B Frames : 0 avg. size 0 bytes
15:12:20: INFO: [???] Average bit-rate : 756400 bits/sec
15:12:20: INFO: [???] Peak bit-rate : 534400 bits/sec
15:12:20: INFO: [???] BUFFERING stream too short for useful statistics
15:12:20: INFO: [???] MUX STATUS: no under-runs detected.
create sub file....done.
running menu muxer....15:12:21: MUXRATE =4400
15:12:21: after read_bmp(): xd=720 yd=480 x0=0 y0=0
15:12:21: Found EOF in .sub file.
15:12:21: warning, sub on line 0 starts before 4s, (some players won't show it)
15:12:21: subtitle duration: -1
15:12:21: ***************** HERE WE GO EVE.ODD *******************
15:12:21: MenuType: EVEN
15:12:21: subtitle_packet_size: 1682
15:12:21: subtitle_packet_size & 1: 0
15:12:21: subtitle_packet_size mod 2: 0
15:12:21: MenuType==""
15:12:21: MenuType=="EVEN"
15:12:21: final subtitle_packet_size: 1682
15:12:21: max_sub_size=1682
15:12:21: subtitle inserted at: 0.176400 sd=0
15:12:21: 1 subtitles added, 0 subtitles skipped, stream: 32, offset: 0.18
done.
create PS sub for file....done.
15:12:21: subtitle_packet_size: 1986
15:12:21: final subtitle_packet_size: 1986
15:12:21: max_sub_size=1986
15:12:21: 1 subtitles added, 0 subtitles skipped, stream: 33, offset: 0.18
done.
15:12:21: Encoding menu...Done.
15:12:21: SVCD2DVD: DVDfolders
15:12:21: -->: DVDFolders creating table of contents
15:12:21: scanning F:\SVCD2DVD_OUTPUT\VIDEO_TS/VTS_01_0.IFO
15:12:21: -->: Creating menu for TOC
15:12:21:
DVD Folders: Processing C:\Users\REDACTED\AppData\Local\Badger I.T.\SVCD2DVD 2.5\2.5.5030.0\menu\menu.mpg...
15:12:21:
15:12:21:
15:12:21: Finalising DVD...Done
15:12:21: Done: Authoring DVD Folders |
...and now the one that crashes...
Title: 2.5
Version: 2.5.5030.0
Service Pack:
Version : 6.1.7100
OSLanguage: 1033
CodeSet: 1252
CountryCode: 44
Local: 0809
CPU Speed: 2.4GHz
CPU FSB: 1.066GHz
15:08:50: Logical CPUs: 4
Video Ram: 1.00 GB
Status: OK
DeviceID: C:
FileSystem: NTFS
FreeSpace: 7.08 GB
DeviceID: D:
FileSystem: NTFS
FreeSpace: 132 GB
DeviceID: E:
FileSystem: NTFS
FreeSpace: 29.8 GB
DeviceID: F:
FileSystem: NTFS
FreeSpace: 52.5 GB
<SVCD2DVD DateTime="03/10/2009 15:08:50" Filename="NONE">
<AssetSet>
</AssetSet>
<DVDStructure>
<MenuButton X1="213" Y1="247" X2="747" Y2="293" FontFamily="Tahoma" FontSize="24" FontStyle="3">5x03 - The Plain In The Prodigy</MenuButton>
</TitleSet>
</DVDStructure>
<Settings>
</Settings>
</SVCD2DVD>
File Size: 2.17 GB
FormatName=mpeg
Num_Frames=62000
DurationInSecs=2586
Duration=00:43:05.9
VideoFFSTNum=0
Width=720
Height=480
Standard=NTSC
BitRate=7240
AudioStreamCount=1
Audio1FFSTNum=1
Audio1Codec=ac3
Audio1BitRate=448
Audio1Channels=6
15:08:50: Leaving 5x03 - The Plain In The Prodigy_S2D.mpg alone. File has Nav Packs
15:08:52: Done: Processing assets for DVD creation
15:08:52: Creating TitleSet # 1
15:08:52: SVCD2DVD: DVDfolders
15:08:52: -->: DVDFolders creating VTS
15:08:52: -->: VTS 01
15:08:52:
15:08:52:
15:10:13:
15:10:13:
15:10:13:
15:10:13: Finalising DVD...
15:10:13: Encoding menu...
TV Standard: NTSC
Aspect Ratio: 16:9
Image size: 960x540
[] 15:10:13: FFmpeg version UNKNOWN, Copyright (c) 2000-2008 Fabrice Bellard, et al.
[] 15:10:13: configuration: --disable-debug --disable-vhook --enable-avisynth --enable-gpl --enable-pthreads --enable-libfaad --enable-memalign-hack --enable-swscale --disable-devices
[] 15:10:13: libavutil 49.12. 0 / 49.12. 0
[] 15:10:13: libavcodec 52. 6. 0 / 52. 6. 0
[] 15:10:13: libavformat 52.23. 1 / 52.23. 1
[] 15:10:13: libavdevice 52. 1. 0 / 52. 1. 0
[] 15:10:13: libswscale 0. 6. 1 / 0. 6. 1
[] 15:10:13: built on Dec 7 2008 19:00:16, gcc: 4.3.0 20080305 (alpha-testing) mingw-20080502
[] 15:10:13: Input #0, image2, from 'C:\\Users\\REDACTED\\AppData\\Local\\Badger I.T.\\SVCD2DVD 2.5\\2.5.5030.0\\menu\\background1.jpg':
[] 15:10:13: Duration: 00:00:00.04, start: 0.000000, bitrate: N/A
[] 15:10:13: Stream #0.0: Video: mjpeg, yuvj420p, 720x480 [PAR 96:96 DAR 3:2], 25.00 tb(r)
[] 15:10:13: Output #0, rawvideo, to 'C:\\Users\\REDACTED\\AppData\\Local\\Badger I.T.\\SVCD2DVD 2.5\\2.5.5030.0\\menu\\backgroundES.mpv':
[] 15:10:13: Stream #0.0: Video: mpeg2video, yuv420p, 720x480 [PAR 32:27 DAR 16:9], q=2-31, 6000 kb/s, 29.97 tb(c)
[] 15:10:13: Stream mapping:
[] 15:10:13: Stream #0.0 -> #0.0
[] 15:10:13: Press [q] to stop encoding
[] 15:10:13: video:49kB audio:0kB global headers:0kB muxing overhead 0.000000%
15:10:13: INFO: [???] mplex version 2.0.0 (2.2.3 $Date: 2004/01/13 20:45:26 $)
15:10:13: INFO: [???] File C:\Users\REDACTED\AppData\Local\Badger I.T.\SVCD2DVD 2.5\2.5.5030.0\menu\backgroundES.mpv looks like an MPEG Video stream.
15:10:13: INFO: [???] Video stream 0: profile 8 selected - ignoring non-standard options!
15:10:13: INFO: [???] Found 0 audio streams and 1 video streams
15:10:13: INFO: [???] Selecting dvdauthor DVD output profile
15:10:13: INFO: [???] Multiplexing video program stream!
15:10:13: INFO: [???] Scanning for header info: Video stream e0 (C:\Users\REDACTED\AppData\Local\Badger I.T.\SVCD2DVD 2.5\2.5.5030.0\menu\backgroundES.mpv)
15:10:13: INFO: [???] VIDEO STREAM: e0
15:10:13: INFO: [???] Frame width : 720
15:10:13: INFO: [???] Frame height : 480
15:10:13: INFO: [???] Aspect ratio : 16:9 display
15:10:13: INFO: [???] Picture rate : 29.970 frames/sec
15:10:13: INFO: [???] Bit rate : variable
15:10:13: INFO: [???] Vbv buffer size : 212992 bytes
15:10:13: INFO: [???] CSPF : 0
15:10:13: INFO: [???] SYSTEMS/PROGRAM stream:
15:10:13: INFO: [???] rough-guess multiplexed stream data rate : 0001248
15:10:13: INFO: [???] target data-rate specified : 10080000
15:10:13: INFO: [???] Setting specified specified data rate: 10080000
15:10:13: INFO: [???] Run-in Sectors = 88 Video delay = 12873 Audio delay = 15876
15:10:13: INFO: [???] New sequence commences...
15:10:13: INFO: [???] Video e0: buf= 0 frame=000000 sector=00000000
15:10:13: INFO: [???] STREAM e0 completed @ frame 14.
15:10:13: INFO: [???] Multiplex completion at SCR=4096.
15:10:13: INFO: [???] Video e0: buf= 49672 frame=000014 sector=00000026
15:10:13: INFO: [???] VIDEO_STATISTICS: e0
15:10:13: INFO: [???] Video Stream length: 50256 bytes
15:10:13: INFO: [???] Sequence headers: 2
15:10:13: INFO: [???] Sequence ends : 0
15:10:13: INFO: [???] No. Pictures : 15
15:10:13: INFO: [???] No. Groups : 2
15:10:13: INFO: [???] No. I Frames : 2 avg. size 16215 bytes
15:10:13: INFO: [???] No. P Frames : 14 avg. size 1231 bytes
15:10:13: INFO: [???] No. B Frames : 0 avg. size 0 bytes
15:10:13: INFO: [???] Average bit-rate : 752800 bits/sec
15:10:13: INFO: [???] Peak bit-rate : 531600 bits/sec
15:10:13: INFO: [???] BUFFERING stream too short for useful statistics
15:10:13: INFO: [???] MUX STATUS: no under-runs detected.
running menu muxer....15:10:14: MUXRATE =4400
15:10:14: after read_bmp(): xd=720 yd=480 x0=0 y0=0
15:10:14: Found EOF in .sub file.
15:10:14: warning, sub on line 0 starts before 4s, (some players won't show it)
15:10:14: subtitle duration: -1
15:10:14: ***************** HERE WE GO EVE.ODD *******************
15:10:14: MenuType: EVEN
15:10:14: subtitle_packet_size: 1705
15:10:14: subtitle_packet_size & 1: 1
15:10:14: subtitle_packet_size mod 2: 1
15:10:14: MenuType==""
15:10:14: MenuType=="EVEN"
15:10:14: WAS ODD
15:10:14: subtitle_packet_size++
15:10:14: final subtitle_packet_size: 1706
15:10:14: max_sub_size=1706
15:10:14: subtitle inserted at: 0.176400 sd=0
15:10:14: 1 subtitles added, 0 subtitles skipped, stream: 32, offset: 0.18
done.
15:10:14: subtitle_packet_size: 2010
15:10:14: subtitle_packet_size & 1: 0
15:10:14: subtitle_packet_size mod 2: 0
15:10:14: final subtitle_packet_size: 2010
15:10:14: max_sub_size=2010
15:10:14: 1 subtitles added, 0 subtitles skipped, stream: 33, offset: 0.18
done.
15:10:14: Encoding menu...Done.
15:10:14: SVCD2DVD: DVDfolders
15:10:14: -->: DVDFolders creating table of contents
15:10:14: scanning F:\SVCD2DVD_OUTPUT\VIDEO_TS/VTS_01_0.IFO
15:10:14: -->: Creating menu for TOC
15:10:14:
15:10:14:
15:10:14:
ERR: Error opening F:\SVCD2DVD_OUTPUT\VIDEO_TS/VIDEO_TS.VOB_0.VOB: No such file or directory |
