Forum archive - RAID considerations
http://www.supermediastore.com/
Forum Archive Home -> Computer -> RAID considerations
RAID considerations
rallynavvie posted 2009 Aug 16 21:24
I'm trying to decide how best to set up my new HDD configuration in my primary workstation. Here are the vital stats:
5x 150GB WD Raptor 10krpm SATA
4x 1TB WD Green 7200rpm SATA
6-ports onboard (Intel SATA)
4-ports PCI-E x8 controller (Adaptec 5405 SAS/SATA)
Currently only one of those five Raptors are installed. I plan on leaving the storage drives as is on the onboard controller in JBOD. The 5405 can run up to 256 drives but I don't have backplanes for all that, just a 4-port SATA/SAS backplane with dedicated cooling. The case holds 6 other HDDs (where I plan on leaving the storage drives).
So with the five Raptors would I be better off doing:
RAID 1+0 with four
RAID 5 across four
RAID 6 across four
RAID 5 across three with a hot spare
There are advantages and disadvantages to both, but since I have a 5th drive available I'm thinking the RAID 10 option would give me the best performance. I generally use RAID 5 for systems at work (like my VMware View system) since they're running on 15k SAS drives, but these are only 10k SATA so I'm not sure I want to have that parity stripe running in tandem on them. This system is mostly dedicated to hosted VMs now since I don't do much video work, but I've been wanting to better utilize the Adaptec controller so I thought I'd give it a try. The RAID would be used for my boot/apps volume. I'm hoping to have the drives here this week and re-install Windows next weekend.
ocgw posted 2009 Aug 16 21:33
rallynavvie :
RAID 1+0 with four
RAID 5 across four
RAID 6 across four
Do a 4 disc RAID0 for fun and post some benches lol
ocgw
peace
edDV posted 2009 Aug 16 22:02
You haven't mentioned your goals or software you want to run.
Why all the Raptors? Are you trying to edit uncompressed video? Expect high noise.
lordsmurf posted 2009 Aug 17 02:58
Why?
ocgw posted 2009 Aug 17 04:43
Honestly, I would use (2) RAID0 arrays for super fast processing from 1 array to the other (I did that once on a Gigabyte mobo w/ (2) RAID contollers
w/ the OS on a partition @ the head of 1 of the arrays
ocgw
peace
rallynavvie posted 2009 Aug 17 07:53
Anyone who mentions simple RAID 0 can GTFO :evil:
Seriously, I don't want to increase the risk to my data which is exactly what RAID 0 does. It is a cheap, risky method of increasing performance which I do not condone for anything other than simple scratch volumes.
I mentioned my use case was with VMs. I also mentioned I wanted to make use of my Adaptec controller since the dual-core processor it has on board is doing nothing right now. Noise is going to be neutral or perhaps less since my old U320 SCSI drives are coming out and the additional Raptors are going in.
I'm looking for server admins and engineers who have used systems with each of the above-mentioned setups to give feedback on their experiences.
jagabo posted 2009 Aug 17 09:02
edDV :
Bragging rights.
Nelson37 posted 2009 Aug 17 09:13
Have only used a few of the different RAIDS and can never keep the numbers straight without looking it up.
Love Adaptec cards. Hate non-standard controllers. Mirroring just seems silly, the secondary drive has the same wear and tear when the primary fails, plus it's slow. The hot spare is the way to go.
Striping benefit falls off with more drives, 2 or 3 seems most effective Four didn't seem to be much faster. Hot spare is a gift from God.
Just to use all 5, I would go with a 3-way stripe, seperate parity drive, and hot spare. Then buy 2 or 3 replacement drives for the shelf. Or a 2-way stripe, hot spare, and the other two for the shelf.
Did I mention how much I really, really like the hot spare?
Also do not forget to check, double-check, and then check again that there are NO compatibility problems between the chosen controller and the drives. This is a nightmare you do NOT want to go through. Had an array that chewed through 6-8 drives over two months before one of the makers admitted to such a problem. Much unhappiness.
stiltman posted 2009 Aug 17 09:48
I would do RAID 5 and save one for hot swap....However, are you sure your onboard controller can do hot swapping?
Also assuming that the one raptor is for your OS, why would you do that?
I would put 2 raptors as RAID1 for OS
I would put 3 raptors as RAID5 for whatever
I would put the 4 1TB's as RAID5 for whatever
rallynavvie posted 2009 Aug 17 11:02
stiltman :
I'm not planning on using the onboard for any RAID other than the JBOD I use for the storage drives. The Adaptec controller does just about anything you could ever want it to do.
Unfortunately the breakout cable I have is 4-device, thus using the 4-drive backplane. The 5th Raptor would be kept around as a spare or sold to a friend. 4-drive RAID 5 with a hot-spare would be idea but I just can't seem to find the mSAS expanders that multiply out to more SATA devices. I thought the only way for that controller to support 256 drives was with backplane expanders?
I think I've exempted RAID 6 from the options since I don't need that much security. My expectation was that drive failures would be infrequent enough that if a failure happened that the rest would last until the RMA returned. With the hot spare I don't think there's any performance hit since it takes over for the dead drive, right? Then when I get the RMA return it essentially becomes the new hot spare when I install it?
ocgw posted 2009 Aug 17 12:04
[quote="rallynavvie"]Anyone who mentions simple RAID 0 can GTFO :evil:
I'm looking for server admins and engineers who have used systems with each of the above-mentioned setups to give feedback on their experiences.[/quote
If you do regular backups what is the harm??????????????????????????????????????????????
duh!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
properly cooled, properly powered systems don't lose drives anyway, unless the drives are chit
ps. @ ANY point did you indicate that your drives would be ANYTHING other than scratch drives, which is all I do other than OS w/ sub-terabyte drives?1?1?!?!?!
pfffffff........
ocgw
peace
rallynavvie posted 2009 Aug 17 12:20
ocgw :
Backups aren't the problem. On average the backup of my OS disk (currently just a single 150GB drive) takes roughly an hour to complete. They also take roughly an hour to re-install. That isn't a big deal. The major impact is downtime and in-flight corruptions. That system runs 24/7 so if it goes down I lose whatever I'm currently working on (in-flight) and I also lose the time until I return to it and get the system restored (downtime). Worst case the DT occurs right as I'm leaving for work or right as I'm headed to bed. That's roughly 8 hours of DT that are possible, a third of a day wasted.
With a proper RAID solution this risk is greatly decreased and there are still performance gains over a single drive solution. In fact with all of the solutions I mentioned there is zero downtime and the rebuilds happen in-flight so that my OS and everything never realizes anything is amiss.
Everyone jumps instantly to the RAID 0 bandwagon because it's a cheap solution. You can start with only 2 drives and most of the controllers support it. More people should be looking into RAID 5 instead since it only requires on more drive and a controller to support it, but at much less risk as the RAID 0 solution. Performance is more than just benchmark numbers, uptime plays a big factor in performance of my machines.
jagabo posted 2009 Aug 17 12:31
ocgw :
Tell that to Google. http://labs.google.com/papers/disk_failures.pdf
ocgw posted 2009 Aug 17 12:38
rallynavvie :
ocgw :
Once again you did NOT say what you were going to do w/ the drives
And why would you need 150GB for your OS let alone multiple 150GB drives
cheap?, bandwagon?, I have more than a dozen drives too rally, I use multiple RAID0 arrays to quickly process (demux-remux) data
You forget who you are talkin' to?, I have 15K SAS drives, 10K Raptors and a LSI Logic Controller too, and a big ass pile of TB+ drives
btw, how often do you lose drives?, if you lose drives on a regular basis you need to get to the root of the flaw in your workstation design theory
You know what? You are freakin' big ass mofo "big shot", buy 1 or 2 more Raptors and go RAID5 to RAID5 for superior thruput and redundancy
ocgw
peace
rallynavvie posted 2009 Aug 17 13:35
rallynavvie :
From my first post :?
lordsmurf posted 2009 Aug 17 14:58
I don't know that you'll get much of a boost. In fact, in my experience, RAID slows down apps.
rallynavvie posted 2009 Aug 17 17:03
lordsmurf :
I've heard that sometimes with concurrent writes but most engineers I talk to say that's usually due to implementation or the controller hardware. I'd be curious to see CPU cycles on systems like that to see if the system isn't being taxed (thus taking away from the applications).
ocgw posted 2009 Aug 17 17:11
lordsmurf :
If RAID slows down your apps you have the wrong cluster and stripe sizes
Cluster and stripe size have to be tailored for the job the RAID array is performing
OK, let's get down to "nuts and bolts"
I have done "exhaustive experimentation" w/ stripe and cluster sizes in RAID arrays
You want to format w/ large clusters and use large stripes for video files, you want small clusters and stripes for the many small files of an OS, if you use large clusters and stripes w/ an OS you lose perfomance and storage space because of "slack space"
32-64kb stripes w/ 4kb clusters for OS, 128-1024 stripes for video
You never said what apps??, what apps need a 750GB volume?
So you are going to seriously use 5 Raptors in a big 750GB RAID array for your "boot and apps"?, that is a lot of apps
In my opinion it would be just rediculus to use 5 raptors for a "boot/apps", once programs are stored in memory they run off the memory and cpu not the drives
You will get a extremely fast boot, but it won't really make your system feel so much faster, now if you are processing large video files going from 1 high performance RAID array to another it makes sense to me
ocgw
peace
edDV posted 2009 Aug 17 17:43
If you're injesting SMPTE-292M HD video off an SDI card you should put all the raptors on the SDI as Raid0 or RAID5/6 and test transfer. Maybe you have enough Raptors for two realtime RAIDs*. The OS/Apps will be happy with a single ATA/SATA (backed up). Why is fast boot a need? A proper install will be up a week or more.
This is a video forum not a bank transaction server forum.
* This will require realtime software.
poisondeathray posted 2009 Aug 17 17:56
edDV :
LOL it will be a HORRENDOUSLY slow boot, but that probably doesn't matter if it's a workstation, or he's using workstation type workflows, he might be booting once a month
I had an Adaptec 5805 with similar dually setup, the initialization alone was 30-40sec. Most server boards have 20-30 sec initalization as well in addition to the controller initialization. Not sure about the Tyan he has, I use Supermicro for my builds, and they all boot slow. So if you are doing this for "boot reasons", forget about it and ditch the controller
@rallynavie - What types of workloads and apps will you be using?
edDV posted 2009 Aug 17 18:01
I still don't understand what work this server/workstation is doing. As said above by someone, you design the system to the problem you want to solve.
poisondeathray posted 2009 Aug 17 18:03
edDV :
That is a VERY relevant question and it has been asked a few times :)
ocgw posted 2009 Aug 17 18:35
poisondeathray :
edDV :
Host Bus Controller cards are notorious for slow initalization, I should know, I have a LSI Logic MegaRAID SAS 8204ELP, but if he is loading multiple VM's into 16-32GB of RAM it might make for overall fast booting, but still a waste of drives if you ask me
ocgw
peace
edDV posted 2009 Aug 17 19:46
So his goal is to load several virtual OS? Strange requirement.
rallynavvie posted 2009 Aug 17 20:01
rallynavvie :
Also from my first post, folks. Maybe I shouldn't use paragraphs for things anymore :lol:
I know boot speed is out the window with this controller, it takes several seconds per drive for init just like the onboard Intel controller does. This system only reboots when required, and I do tend to batch my system updates monthly since stupid Windows updates seem to require rebooting more often than not these days :evil:
My single 150GB is getting full, running at about 15GB remaining, and I don't like running drives over 90% capacity (which it's obviously past that now). I could free up several GB here and there by cleaning off some games that I don't play as much anymore but I tend to only clean them off when I'm sick of them so I did need something bigger than 150GB at some point. Adobe Master Collection takes up about a tenth of that disk, too. I don't need 750GB which is another reason why I'm looking at a RAID 10 or RAID 5 solution. 300GB should be enough for quite a while but 450GB makes me consider moving my vdisks to this volume as well and see how it handles. Right now the vdisks are on the storage drives but I have more vdisks than drives so essentially there are multiple OS and their applications running on each 7200rpm SATA drive. There are many times you can hear them winding up for intensive I/O as the VMs vie for bandwidth. I'm thinking of moving the most active VMs to the RAID volume and see what happens. Most of those use 40GB vdisks (though I may not pre-allocate them if the new volume offers up enough performance).
ocgw posted 2009 Aug 17 20:45
edDV :
We still have no idea what his VM machines are doing and what apps they run, he insinuates we can't read, when he in fact "doesn't get it", the apps his VM's run and the file sizes they use dictate what type of RAID is best and how they should be "fine tuned" by cluster size and stripe size
I will pose the question as simple as humanly possible
1. Why are you hosting VM's?
2. What programs do your VM's run?
I admit to being curious for some time
ocgw
peace
rallynavvie posted 2009 Aug 17 21:31
I don't need granular RAID settings, just pros and cons between the array configurations I have listed. Fine tuning comes later but the array configuration is the more important consideration now.
Many of those VMs sit idle or have little to no disk usage, but they get rebooted or recompiled on occasion which can slow down any others running on the same logical disk. Most of the performance is mitigated by memory since that's usually where VM performance lies (at least with VMware products).
Ideally I would offload these to an ESX box like I run at work but I don't really want to run more than one machine at home if I don't have to. I also prefer Workstation's host integration over console access via VI Client, it makes testing without a SAN so much easier. I tend to take my work home with me sometimes because of these enhancements over the ESX environment and then repackage the VMs to take back to work.
As to specific workload on these I cannot go into much detail due to a reason I just listed. I can say that the two Windows Server builds run SQL and JBoss for JRE application hosting. There are also very equivalent versions running on Ubuntu and RedHat. These communicate with clients running Windows XP, Windows Vista, Windows 7, and Ubuntu desktops. I'm keeping this high-level for a reason. I do run copies of the Windows and Linux for my own enjoyment as well such as an Ubuntu web browser that reverts to snapshot on reboot for more secure browsing, a Windows 7 machine to get familiar with the upcoming OS (I learned Linux running it as a VM as well), and a thin build called Untangle which is one of the best standalone firewalls I have come across. I'm also chipping away at an OSX VM (OSX is unsupported in VMware) which requires some custom KEXTs for graphics acceleration similar to what VMware Tools does for most other guest OS.
ocgw posted 2009 Aug 17 21:46
rallynavvie :
I give up, maybe if he told us what he is doing he would have to kill us lol
ocgw
peace
Nelson37 posted 2009 Aug 18 08:53
I think enough has been explained to get the general idea. Speed, size, and redundancy. Clearly some cash has been spent, with extra money for extra speed.
Three drive stripe with hot spare and cold spare on the shelf. Put the V-disks on the array, you paid the money for the hi-speed, might as well use it. I would not sell the fifth drive, unless you intend to upgrade the array again in the next few years. Keep your current drive out of the system after cloning it to the array. Keep it as a fallback for a while.
I would also run some live tests so as to get familiar with replacing a failed drive and rebuilding the array with both hot and cold spares. Good to have this down pat before you Need to Know, it also gives you a real nice warm fuzzy. The software has options to both re-create the array with all data safe and sound, and also to re-create a nice, clean, blank array, that's a distinction you want to be real clear on.
Most hi-end Acaptecs have significant caching RAM as well as their own processor. Depending on the type of HD access, the performance improvement can be dramatic. Almost gives me wood.
For those who don't know, comparing such a controller to most on-board RAID controllers is like comparing a racehorse to a plowhorse. Some mobo RAID in a simple performance stripe are actually slower than the standalone drives. Many expensive ones are not much better. Adaptecs are almost always tops in class.
rallynavvie posted 2009 Aug 18 09:35
Nelson37 :
256MB of RAM, BBU, and dual-core CPU on the 5405. I had read reviews of the stock heatsink not being quite up to the task without significant airflow so the one I picked up had a Zalman passive MCH cooler attached. I wasn't able to use the internal chipset fan that came with my Lian Li V1010 but I'm thinking I could drop it down to push a little more air over that card if it needs it.
I wanted more than the 6 onboard SATA devices and got a great price on the Adaptec (with the intention of moving it to a storage array when the 5396 retires) but I just didn't feel right using it to simple host 4 more SATA drives. And FWIW I got a killer deal on the four Raptors as well otherwise I wouldn't be entertaining such a lofty idea. At first I was simply going to replace the 150GB with a 300GB Raptor but then I saw these others for sale for less than the 300GB version and thought it was the perfect opportunity. And they're all still under warranty for another 2 years :)
stiltman posted 2009 Aug 18 09:50
Just go RAID5 and be done with it :)
rallynavvie posted 2009 Aug 18 21:08
It sounds like RAID 5 with a hot spare is probably the way to go with the hardware I have. I had almost all but decided on RAID 10 when I posted but between here and some of the engineers at work the other option is going to give good performance, better drive utilization, and still retain the redundancy (just in a different matter). I'll post some before/after later.
rallynavvie posted 2009 Oct 07 18:46
Finally got the drives in and started putting things together. I don't have time to take down my workstation and install this quite yet but maybe tomorrow or over the weekend. I don't really enjoy re-imaging my machine but it's been running for over a year so it wouldn't hurt to start over with a clean install.
I had to get right-angle adapters for the SATA connections on the backplane so I could use the SFF-8087 cable for the controller. The big heatsink on the controller is a northbridge heatsink to help cool the dual-core processor that lives on that controller. Apparently that chip runs really hot and the stock heatsink doesn't keep up.
This is the drive cage, controller, and drives with the drive "handles" on them for the backplane:
Here they are tucked away inside the backplane:
lordsmurf posted 2009 Oct 07 23:30
The only RAID that I do is RAID1 on some working drives. It's an "instant backup" for drive hardware fails, should one happen. Not a bullet-proof backup for all fail scenarios, but good enough to fight the problems I have had historically.
RAID0 screws up drives. To even call it "RAID" is a misnomer.
RAID5+1 is probably my favorite. Needs 6 drives, though. :shock:
rallynavvie posted 2009 Oct 08 08:01
lordsmurf :
I used RAID 1 when I was running my video business for the main storage drive so that I could have a backup of it should the one fail. As they filled up I would replace it with a similar size drive (was using 250GB drives at the time), clear the array, and start over. The full drive was kept at a "data storage facility".
If you had read the thread I don't condone RAID 0 for anything other than scratch space. I changed my mind on this project and decided to run 4-disk RAID 5 since I can get a replacement drive cross-shipped in a few days and the degraded performance of the remaining 3 disks is still better than a single drive. I can live with that. The other options were to use 3-disk RAID 5E (the 4th is the hotspare) or a basic RAID 10. Since this is OS/apps volume I would rather have the better read performance of the option I chose instead of the faster write access of RAID 10. Looking at drive activity there aren't a great amount of writes to the OS/apps volume.
edDV posted 2009 Oct 08 10:36
RAID 1 is not a true "backup". It will protect you from a drive failure but not file corruption or human error which modifies both copies. You still need a separate backup to go back in time should such errors occur.
rallynavvie posted 2009 Oct 08 10:43
rallynavvie :
Like I said, the idea was a backup should a drive fail. For that particular drive it only consisted of final DVD ISOs so there wasn't much chance of simple data corruption as the build had already been tested prior to migrating it to the storage volume. In-flight projects were backed up using nightlies.
rallynavvie posted 2009 Oct 09 18:41
I hate my luck with putting computers together. My own never seem to go according to plan :lol:
So I tried installing the drive bay this afternoon and the fan on the back of the drive cage runs right into the EPS12V 8-pin connector on the leading edge of the board. Now I had figured it would be a tight fit but since both my case and the drive bay are both Lian Li and both use the same design that they would have checked to make sure this drive cage would fit on their cases (of like design) with an EATX board. Furthering this point is the fact that most users of this hot-swap-capable SATA backplane would be using a workstation-class system with, likely, an EATX board. But this is not the case, and further irritating is the fact that the fan is offset towards the board instead of away from it. I might be able to modify the cage itself to shift the fan to the other side but I hate cutting apart such an otherwise well-built component.
The other option is to run four 10krpm Raptors without any airflow over them except what the 120mm exhaust fan is pulling through the case. At least the HDDs would be on the leading edge of that cool air, but from the looks of the drive spacing above I don't think that would be wise?
Alternatively I could rout cables outside my case and run the drive cage out in the open :roll:
rallynavvie posted 2009 Oct 11 15:33
Pulled the fan off to see if case airflow would be enough. Unfortunately I haven't found an app that can monitor the HDD temps past the controller so I'm still searching. Since they're going to be idle and unused for now they should be fine.
HD Tach read an average of about 170 MB/s sequential read with a 769 MB/s burst. The short test showed much higher results of 300 MB/s. Everest tested sequential write speeds averaged 230 MB/s. Should make a great OS/application volume since average seek times are still down around 5ms.
Taking the fan assembly to a fab shop to see if they can rig something up that will fit on the back of the drive cage. Once that's in place I will re-install and start fresh.
ocgw posted 2009 Oct 11 15:49
rallynavvie :
Seriously nice i/o performance rallynavvie
ocgw
peace
rallynavvie posted 2009 Oct 15 07:34
I completed my tests a couple days ago and loaded up a fresh install of Vista on the new array to begin the transition from my single boot drive. Despite those who claim faster Windows boot times as a benchmark for RAID I have seen my boot times increase dramatically. The reason is obvious (and I'll let you smart folks guess what that is), I just never really thought about it until I was doing a bunch of reboots while installing updates :lol:
The read performance combined with the seek times of the 10krpm drives did well in some of my tests, one of which was installing BF2 to that volume and watching load times of the really large maps. I also moved a few of my resource hog VMs over to that volume to see how well they performed. Using two VMs simultaneously on that volume showed a significant performance increase over running them simultaneously on a single 7200rpm drive.
I mitigated the heat issue with the drives by customizing the backplane fan to fit around my EPS12V connector. They're running comfortably now. The handles on them act like heatsinks which may have been a design feature of the backplane (+1 for Lian Li). The controller still runs ridiculously hot, sometimes reaching 92C even with that big heatsink on it. Funny thing is it still states it's operating within "Normal" temps. I'm going to put a 40mm chipset fan on the side of the heatsink to cool it down, I've got one which makes almost no noise.
As to the noise I was somewhat surprised that four Raptors do not make 4x the noise of a single one. The HDD access noise is completely tolerable even with this being a quiet HTPC build. And yes, you'd be surprised what really good case design and a little effort can do to keep a system like mine quiet.
rallynavvie posted 2009 Nov 02 19:55
I ditched the new install of Vista on the array and decided to keep my OS on the single Raptor and instead use the array for applications and VMs. I could have run the VMs, apps, and OS all on this array but with the amount of VMs I've been using on this machine (generally 3-4 are running at any given time) I thought it best to isolate the array. The memory on the controller combined with the drive buffers have produced a wonderful project drive for multiple VMs. The other advantage to this is I can send the drives into low-power mode when I'm away from home by putting the VMs to sleep, something I might not be able to do with an active host OS on the array.
Login/Register to our forum to be able to post here.
DVDFab DVD to DVD lets you backup DVDs to DVDr, AVI or MP4 for portable devices. More info or download trial!
About   Advertise   Forum Archive   RSS Feeds   Statistics
