Forum Archive Home -> VCDEasy General -> Question with Main Menu.
Question with Main Menu. |
| murraymile posted 2005 May 03 16:29 |
| I'm using VCDEasy 2.0 comm. version and was woundering what I might of did wrong. I have a main menu that is a mpg formate due to because, I use Adobe Premiere to add some video effect and audio in the back around. Well, when I put it in my dvd, it works but.... I have to hit the play button to view or even start the main menu.
I was woundering if its my DVD or if its suppose to do that to all DVD's. Maybe I didn't do something wrong. help please -Calvin- |
| vitualis posted 2005 May 04 02:52 |
| VCDs do not necessarily "autoplay" when you put it in a DVD player. If your DVD player doesn't "autoplay" VCDs, then there is not much that you can do about it.
Regards. |
Login/Register to our forum to be able to post here.
